#1 2020-12-19 07:04
Q4OS 3.13 release
Thanks for the update folks.
#2 2020-12-19 08:12
itsoulos
Re: Q4OS 3.13 release
Good morning everyone thank you for the new release. I currently use Q4OS 4.2 without any problem in
two pcs
1) Dell All in one 5480
2) Huwaei laptop D14
My only problem is that KDE is outdated
regards
#3 2020-12-20 01:44
Updated my Dell E6420 to 3.13 with no issues using the KDE version. Installed 3.13 KDE to a Dell E6400 and E6420 with no issues.
Ran a live session with the TDE version on my E6420 as well with no issues.
Ill second itsoulos comment, as the 5.14.5 KDE version is quite old and the kernel is still 4.19. I could enable backports to get a newer kernel but honestly, thats just part of being Debian based, stability over being more up to date with certain packages.
#4 2020-12-20 21:13
Just picked up a Dell E4300 from a friend of mine and will probably try the TDE version on it to see how it runs on older hardware. This is the best TDE version Ive tried with Q4OS and most of the niggles I had before seem to be gone.
#5 2020-12-21 06:57
I just wish the developers would put out a changelist as it helps to show the world the work going on behind the scenes smile
#6 2020-12-21 17:07
Totally agree bin.
#7 2020-12-24 11:23
You can get an info from the release announcements:
https://www.q4os.org/blog.html
or more detailed changelog:
https://www.q4os.org/changelog-q4os3
#8 2020-12-24 12:55
Thank you!
#9 2020-12-24 17:50
smile
#10 2021-01-13 15:01
cool
#11 2021-01-14 18:40
itsoulos
After some upgrades now I run the latest kde (5.20.5) with almost the latest kernel (5.10.0-1)
