#1 2020-12-04 03:33
(SOLVED) Problem with kernel
I installed linux-image-5.8.0-0.bpo.2-amd64 from backports, didn't get any errors and the system "works fine" so far, however, after rebooting the kernel's not being used by the system but the previous one; linux-image-4.19.0-11-amd64.
Also,
$ dpkg --list | grep linux-image
ri  linux-image-4.19.0-11-amd64                   4.19.146-1                           amd64        Linux 4.19 for 64-bit PCs (signed)
ii  linux-image-5.8.0-0.bpo.2-amd64               5.8.10-1~bpo10+1                     amd64        Linux 5.8 for 64-bit PCs (signed)
ii  linux-image-amd64                             4.19+105+deb10u6                     amd64        Linux for 64-bit PCs (meta-package)
According to that, linux-image-4.19.0-11-amd64 isn't even installed.
$ dpkg --status linux-image-4.19.0.11-amd64
dpkg-query: package `linux-image-4.19.0.11-amd64' is not installed and there's no available information.
Use dpkg --info (= dpkg-deb --info) to examine archive files
Not installed? But
$ uname -r
4.19.0-11-amd64
So, what's going on? I don't know what to do here since this is the first time I see something like this. Thanks in advance for your answers.
#2 2020-12-04 07:10
Re: (SOLVED) Problem with kernel
linux-image-4.19.0-11-amd64 from your dpkg --list query is not the same as
linux-image-4.19.0.11-amd64 in your dpkg --status query.
#3 2020-12-04 09:13
What is output of commands:
$ apt policy linux-image-4.19.0-11-amd64
$ dpkg --get-selections | grep linux-image
Did you install the new kernel using the command:
$ qinst-kernel-bpo
#4 2020-12-04 12:28
How so? Why do you say that? It's the same.
linux-image-4.19.0-11-amd64:
  Instalados: 4.19.146-1
  Candidato:  4.19.146-1
  Tabla de versión:
 *** 4.19.146-1 500
        500 http://ftp.debian.org/debian buster/main amd64 Packages
        100 /var/lib/dpkg/status
linux-image-4.19.0-11-amd64                     deinstall
linux-image-5.8.0-0.bpo.2-amd64                 install
linux-image-amd64                               install
$ qinst-kernel-bpo
No, I didn't. I used
sudo apt-get install -t buster-backports linux-image-5.8.0-0.bpo.2-amd64
Should I used that one instead? By the way, I meant to ask this before bot forgot to, how do I choose a different kernel at boot? I tried pressing shift key like most distros do but it didn't work.
#5 2020-12-04 14:06
First edit the "/etc/default/grub" file, set values:
GRUB_TIMEOUT_STYLE=menu
GRUB_TIMEOUT=4
and run:
$ sudo update-grub
The 4.19 kernel seems to be half de-installed, so run the following:
$ sudo apt --purge reinstall linux-image-4.19.0-11-amd64
"Esc" key should do the job.
Yes, we recommend to use the "qinst-kernel-bpo" script as it takes care about installing firmware from backports, which is more related to the kernel.
Reboot and post the result here please.
#6 2020-12-04 15:25
GRUB_TIMEOUT=4
and run:
$ sudo update-grub
Thank you that worked! smile
linux-image-4.19.0-11-amd64                     install
And
uname -r
5.8.0-0.bpo.2-amd64
Thanks!
#7 2020-12-04 15:27
I just saw what you meant and you're right. Seems like a typo since I used "-" and then "." and clearly they're not the same.
#8 2020-12-04 16:10
Thanks for the info. Please note, we don't recommend using other than the default Debian kernel because of stability, see  https://www.q4os.org/dqa011.html#system.6
#9 2020-12-04 20:21
No problem. smile Thanks for the tip and the helpful link. I do have a question though, from that link I read:
If you prefer for some reasons the latest linux kernel, run the auto-installation script in terminal to easily install it from backports repository:
$ qinst-kernel-bpo
Does that mean the script will install the very latest kernel? For instance, linux-image-5.9.0-0.bpo.2-amd64-unsigned is the latest available in backports, but it's unsigned, I don't know what the implications of being "unsigned" are exactly but I presume "signed" is better. Would qinst-kernel-bpo install that one?
#10 2020-12-04 22:01
I tried to lay out the post to make it easier to see, and glad you found it. smile
