#1 2020-09-25 11:18
laurent
Install an AppImage application - Bitwarden
[I'm french speaker only, this is a Google Translate ... sorry! sad ]
Hello,
I am a new LINUX and Q4OS user
I would like to install Bitwarden-1.22.1-x86_64.AppImage but I don't know how.
Could you help me please
Thank you
I am a happy user of Q4OS Centaurus, Trinity
#2 2020-09-25 12:49
Re: Install an AppImage application - Bitwarden
Download the Appimage
Right click on the file>permissions>Make Executable or check box Is Executable
Double click file - it will prompt to integrate into Menu - say yes.
That's it.
Téléchargez l'Appimage
Faites un clic droit sur le fichier> permissions> Rendre exécutable ou cochez la case Est exécutable
Double-cliquez sur le fichier - il vous invitera à s'intégrer dans le menu - dites oui.
C'est tout.
#3 2020-09-25 17:18
laurent
[Google Translate]
Thanks Bin
But another problem arose. After downloading the AppImage file, when I right click on the file, Konqueror crashes and returns an 11 (SIGSEGV) signal.
I made the file executable with the command: chmod a + x Bitwarden.appImage
then I tried to run the file by double click ==> same Konqueror crash problem ???
#4 2020-09-26 06:18
OK - in Konqueror go to the folder containing the appimage.
Right click - Open Terminal Here.
Then enter
./Bitwarden-1.22.1-x86_64.AppImage
However, on the Bitwarden download page under Desktop Installation Options there is a link to a deb file - which is preferable.
https://vault.bitwarden.com/download/?a … ariant=deb
or
https://github.com/bitwarden/desktop/re … -amd64.deb
OK - dans Konqueror, accédez au dossier contenant l'image de l'application.
Faites un clic droit - Ouvrez le terminal ici.
Entrez ensuite
Cependant, sur la page de téléchargement de Bitwarden sous Options d'installation de bureau, il existe un lien vers un fichier deb - ce qui est préférable.
ou
#5 2020-09-28 17:27
laurent
thank you very much
I installed Bitwarden from the .deb file
#6 2020-09-29 06:28
smile
