#1 2020-06-06 07:42
postquantum
AMD64 btrfs Partion - crash
Hello,
I try to install Q4OS the first time, all donw via the Q4OS setup assistent (Icon).
Partitionen
Q4OS btrfs
Data btrfs
SWAP
The Q4OS installation crashed:
Boost.Python-Fehler in Job "mount".
Command '['btrfs', 'subvolume', 'create', '/tmp/calamares-root-_u912se0/@']' returned non-zero exit status 1.
None
Traceback:
File "/usr/lib/x86_64-linux-gnu/calamares/modules/mount/main.py", line 136, in run
    mount_partitions(root_mount_point, partitions)
  File "/usr/lib/x86_64-linux-gnu/calamares/modules/mount/main.py", line 78, in mount_partitions
    root_mount_point + '/@'])
  File "/usr/lib/python3.7/subprocess.py", line 347, in check_call
    raise CalledProcessError(retcode, cmd)
Can I use btrfs for the Partitions to install Q4OS?
If yes, why it was not working in my case?
Kind Regards
