#1 2020-04-30 11:20
vmrey
no puedo actualizar
hola, hace unos meses que lo instale y anda bastante bien, pero no puedo actualizar el sistema, No se de que me perdi. Como o que tendria que  hacer? y tampoco nunca me aviso que tengo alguna actualizacion.
saludos, gracias
#2 2020-04-30 20:12
Re: no puedo actualizar
vmrey wrote:
...snip
Google Translate wrote:
Hello, a few months ago I installed it and it is quite good, but I cannot update the system, I don't know what I missed. How or what should I do? And I also never notice that I have any updates.
greetings thank you
Please use the a translation service (like Google Translate) to post here otherwise we all have to if we want to help.
Please let us know...
1. system type (amd64 armxx, etc)
2. DE used (Plasma/TDE/etc)
3. image used for installation.
#3 2020-04-30 23:27
vmrey
Well download hardinfo but it does not say much, ja was spent to make an operating system but the name does not appear.
-Equipment-
Processor: AMD Athlon (tm) 64 X2 Dual Core Processor 4400+
Memory: 2042MB (965MB used)
Computer Type: Desktop PC
Operating system: Debian GNU / Linux 10 (buster)
Username: nacho (nacho)
Date / Time: Thu Apr 30, 2020 7:22:12 PM -03
-Screen-
Resolution: 1440x900 pixels
OpenGL renderer: NV46
X11 Provider: The X.Org Foundation
-Audio devices-
Audio adapter: HDA-Intel - HDA NVidia
As I remember, install the Trinity version, I think the middle one, which has few programs.
#4 2020-04-30 23:42
vmrey
good checking, install the update manager
something like this should be installed, or warn that it is not installed.
I would give the theme as finished, I try it a few days to see if it works,
Thank you
#5 2020-05-01 08:32
Can you open a terminal and post the output of
sudo apt update
