#1 2020-04-04 12:12
celtico
Problems install progress
Hello,
I am from Spain,  and I have a problem for update q40s.
I run Desktop Profiler and install applications, but I have the problems  "please run dektop profiler tool".
what its  the problem??.
thanks
#2 2020-04-04 15:41
Re: Problems install progress
You might need to reboot to ensure a clean system and if the problem remains you could try running the desktop profiler again and report any output or dialogs.
#3 2020-04-04 18:22
celtico
the problem in in the install.
Desktop Profiler
Checking qaos desktop...
system configured properly, no additional action es needed
sudo
a password is required
finishe ok
and I can't update anything
#4 2020-04-04 18:30
Are you trying to install Q4OS?
If you have already installed can you open a terminal and enter the command
sudo apt update
and enter your user password when asked, and then copy/paste the output here.
#5 2020-04-04 18:37
celtico
Yest,  centaurus i386.
that command doesn't work.
use apt-cdrom to make apt recognize this cd ...  and more.....
(I installed from usb, not from cd)
#6 2020-04-04 18:39
@celtico
Are you running Desktop profiler as the first system user ?
#7 2020-04-04 18:42
celtico
yes.
#8 2020-04-04 19:23
Please run in terminal and post output here:
$ cat /etc/apt/sources.list
#9 2020-04-04 19:54
celtico
ok
line commented out by installer because it failed to verify:
deb htt  security.debian.org/debian-security buster/updates main contrib non-free
deb-src htp://securit.........
buster-updates, previously know as volatile
a network mirror was not selected during install. the folowing entries are provided as examples, but you should amend them as appropiate for your mirror of choce.
deb http.....   buster-updates main contrib non-free
deb-src htp:...... buster-updates........
#10 2020-04-04 20:02
Something must have gone wrong, because the Q4OS installation was not completed.
Please run in terminal:
$ reportq4
and send the debug file generated via email support@q4os.org , or attach it here to analyze.
#11 2020-04-05 14:19
We have received all the files needed via e-mail, we are analyzing the issue now. We will report back as soon as some information is available. Thanks for reporting.
#12 2020-04-06 11:38
We have found a glitch in Q4OS install-cd, that could lead in some rare cases to an incomplete installation. The bug will be fixed in the next Q4OS install-cd revision.
@celtico
Thanks for the detailed reporting.
#13 2020-04-09 22:31
celtico
I solved the problem with
We need to edit the line
%sudo   ALL=(ALL:ALL) ALL
and look like this:
%sudo  ALL=(ALL:ALL) NOPASSWD: ALL
We can save the file and exit.
I wrote:  NOPASSWD: ALL
And the first step worked
but now I have the nex problem
Synaptic package manager setup wizard
"failed to detec q4os system version,  canceling installation...
Package manager:
Sorry software centre:  synaptic package manager isnt installed  please install it first
#14 2020-04-09 22:37
As mentioned above, your Q4OS installation has not completed, it's just broken, due to bug in Q4OS installer. A new fixed installation media will be released in a few weeks.
#15 2020-05-12 11:48
The bug is fixed, a new installation "install-cd" 3.11 media are immediately available for download from the Q4OS website https://www.q4os.org/downloads1.html
