#1 2019-11-17 21:52
eol1
I can't upload my forum avatar.Pas moyen de téléverser mon avatar
I can't upload my forum avatar wich is a 60x60.png - 15,3 ko- The file is too large for the server .What can i do please ?
Pas moyen de téléverser mon avatar - 60x60.png - 15,3 ko Le fichier est trop gros pour le serveur.Que faire svp ?
/Q4os Centaurus TDE /Notebook Asus /Ram 4GB /dual core cpu
#2 2019-11-17 22:04
Re: I can't upload my forum avatar.Pas moyen de téléverser mon avatar
You could use convert to resize the image very slightly to allow uploading, see the man page for usage (man convert) but a typical example would be
#3 2019-11-17 23:22
eol1
Thankyou Dai_trying
Still no luck
Ufw is enable and ufw limit ssh/tcp.Maybe the firewall?
#4 2019-11-17 23:30
eol1 wrote:
Thankyou Dai_trying
Still no luck
You should have resized it smaller, original size was 60x60 and so you need to make the new size smaller, maybe 55x55 will work? And I don't imagine firewall will have any relevance here.
#5 2019-11-17 23:37
eol1
sudo ufw disable doesn't work.The problem isn't my firewall.Maybe a short text description of my avatar in the signature would be better...
#6 2019-11-17 23:44
eol1
No luck
It's not so important anyway
I really enjoy this wondefull OS !
#7 2019-11-17 23:51
eol1
Thanks for your attention.
#8 2019-11-18 00:08
What is the size of the avatar after changing it to 55x55? And you are welcome. smile
#9 2019-11-18 00:30
eol1
Properties say 14,9 ko
#10 2019-11-18 00:41
eol1
I tried to upload a desktop screenshot 1,3 Mo  to the -show us your desktop section- and this was blocked too so i don't know .I have got a good internet connection,well...
#11 2019-11-18 00:46
eol1
Firefox is firejailed and use privoxy + opendns -not sure if there's any relevance here...
#12 2019-11-18 00:51
eol1
I tried with falkon and less restrictions - no way
#13 2019-11-18 00:56
eol1
Avatar in hollydays
#14 2019-11-18 00:58
Your avatar will need to be smaller, the limit is 10Kb, so if you reduce it further (maybe 40 or 45 pixels) then the size will reduce accordingly.
If you want to post a screenshot, the easiest way is to use a web image hosting service, I use imgur but there are many available, and then just post the link to it.
#15 2019-11-18 00:59
eol1
Time to sleep for me,i got to work tomorrow,Thank you
#16 2019-11-18 01:07
eol1
I will do that tomorrow and explore web image hosting service or choose the one you say,yes i will do that.Thankyou
#17 2019-11-18 18:26
eol1
I'm not very easy with gim or inkscape so i downloaded it from https://www.iconninja.com/ 48x48.png  2,8 ko
I choose caseimages for web hosting image wich is french and allright for my needs
So Qsolved - Thank you from Saint-Flour 15100
#18 2019-11-18 18:32
Glad you got it sorted and you are welcome smile
