#1 2019-09-09 15:12
dart
Today's Update and Zap
Hello,
Noticed the update manager icon loaded this morning.
Since it always crashes when I use it, I downloaded the upates by terminal.
After the update, I rebooted and wifi was off.
Tried to reconnect with wifi password and nothing.
So I booted into windows and same issue there; the wifi adapter was non-existent.
After numerous failed attempts to correct the issue, I shut the system off and disconnected all peripherals and power cable.
After another reboot, the adapter was found by both systems as usual.
Don't know if this was a co-incidental issue or if something in the update could cause this.
