#1 2019-08-15 14:09
Jerome
USB problems in Centaurus
I never had any problems with Scorpion, but since using Centaurus I'm getting errors when trying to run video (mp4) files from a usb stick. This is the error message I get when trying to run the video which has been copied to the usb (using SMplayer) :
/usr/bin/mpv --no-config --no-quiet --terminal --no-msg-color --input-file=/dev/stdin --no-fs --hwdec=no --sub-auto=fuzzy --no-input-default-bindings --input-vo-keyboard=no --no-input-cursor --cursor-autohide=no --no-keepaspect --wid=56623124 --monitorpixelaspect=1 --osd-level=1 --osd-scale=1 --osd-bar-align-y=0.6 --sub-ass --embeddedfonts --sub-ass-line-spacing=0 --sub-scale=1 --sub-font=Arial --sub-color=#ffffffff --sub-shadow-color=#ff000000 --sub-border-color=#ff000000 --sub-border-size=0.75 --sub-shadow-offset=2.5 --sub-font-size=50 --sub-bold=no --sub-italic=no --sub-codepage=ISO-8859-1 --sub-pos=100 --volume=104 --cache=auto --screenshot-template=cap_%F_%p_%02n --screenshot-format=jpg --screenshot-directory=/home/jules/Pictures/smplayer_screenshots --audio-pitch-correction=yes --volume-max=110 --term-playing-msg=MPV_VERSION=${=mpv-version:}
INFO_VIDEO_WIDTH=${=width}
INFO_VIDEO_HEIGHT=${=height}
INFO_VIDEO_ASPECT=${=video-aspect}
INFO_VIDEO_FPS=${=container-fps:${=fps}}
INFO_VIDEO_FORMAT=${=video-format}
INFO_VIDEO_CODEC=${=video-codec}
INFO_AUDIO_FORMAT=${=audio-codec-name}
INFO_AUDIO_CODEC=${=audio-codec}
INFO_AUDIO_RATE=${=audio-params/samplerate}
INFO_AUDIO_NCH=${=audio-params/channel-count}
INFO_LENGTH=${=duration:${=length}}
INFO_DEMUXER=${=current-demuxer:${=demuxer}}
INFO_SEEKABLE=${=seekable}
INFO_TITLES=${=disc-titles}
INFO_CHAPTERS=${=chapters}
INFO_TRACKS_COUNT=${=track-list/count}
METADATA_TITLE=${metadata/by-key/title:}
METADATA_ARTIST=${metadata/by-key/artist:}
METADATA_ALBUM=${metadata/by-key/album:}
METADATA_GENRE=${metadata/by-key/genre:}
METADATA_DATE=${metadata/by-key/date:}
METADATA_TRACK=${metadata/by-key/track:}
METADATA_COPYRIGHT=${metadata/by-key/copyright:}
INFO_MEDIA_TITLE=${=media-title:}
INFO_STREAM_PATH=${stream-path}
--audio-client-name=SMPlayer --term-status-msg=STATUS: ${=time-pos} / ${=duration:${=length:0}} P: ${=pause} B: ${=paused-for-cache} I: ${=core-idle} VB: ${=video-bitrate:0} AB: ${=audio-bitrate:0} /media/jerome/Data/revolutions.mp4
Playing: /media/jerome/Data/revolutions.mp4
[ffmpeg/demuxer] mov,mp4,m4a,3gp,3g2,mj2: moov atom not found
[lavf] avformat_open_input() failed
Failed to recognize file format.
Exiting... (Errors when loading file)
I also get a "file not recognized" error when trying to play the mp4 after plugging the usb into my TV. I have 2 usb sticks and am getting the same errors when using both, so it's unlikely to be a problem with drives, and also I've tried copying the mp4 file using the terminal instead of drag and drop -- same result.
Any suggestions? Thanks.
