#1 2019-07-27 16:50
[FIXED]Q4OS Centaurus 32bit / i386 Checksum verification failed
I have downloaded and wrote Q4OS Centaurus, Trinity, install-cd - 32bit / i386 on my USB Flash drive using dd utility as usual.
ISO check showed, that it has been written correctly. MD5 checksums matched.
https://drive.google.com/open?id=1-j5It … 8xJKo5ToDs
But, when I tried to perform checksum verification after booting from USB Flash drive, checksum verification failed.
https://drive.google.com/open?id=1-mR8f … wQ_sgo7cvx
https://drive.google.com/open?id=1-lCfZ … hglFpc9Dsy
Why?
#2 2019-07-27 20:00
Re: [FIXED]Q4OS Centaurus 32bit / i386 Checksum verification failed
This is a Q4OS install-cd issue, checksum saved in the media doesn't match the real file. We will fix that as soon as possible. Which way did you develop this dialog ? Thanks for reporting.
#3 2019-07-27 20:59
Thank you!
Sorry, I do not understand your question...
#4 2019-07-27 22:07
The question is, how did you get this one ?
A brief step by step would be appreciated.
#5 2019-07-28 10:10
Well, we are now able to reproduce the issue, thanks.
#6 2019-07-28 15:21
Here is the sequence, I used to get this menu.
https://drive.google.com/drive/folders/ … sp=sharing
#7 2019-07-28 22:34
Fixed, you can download updated images from the usual location https://www.q4os.org/downloads1.html
