#1 2019-06-21 15:37
gazza
display problem (TQWidget)
hi Q4os
i just updated to 3.7 trinity. the system does not load the colours correctly from i believe about the point that (starttde) gets executed. there is also a glitch where if you try to adjust the colours from -> trinity control centre / appearance & themes / colours / color scheme   the task bar starts to go crazy, my terminal reports a problem with TQWidget.
if anybody else is having the same trouble or knows how to fix this then please let me know
warm regards
gaz
#2 2019-06-21 16:45
Re: display problem (TQWidget)
Please specify the installation media you have installed Q4OS from.
What color scheme ? A screenshost would be helpful
gazza wrote:
... there is also a glitch where if you try to adjust the colours from -> trinity control centre / appearance & themes / colours / color scheme   the task bar starts to go crazy ...
What color scheme ? What does taskbar do ? Please describe more exactly. A screenshost would be helpful
gazza wrote:
... my terminal reports a problem with TQWidget.
What does terminal report exactly ? On what command ?
#3 2019-06-21 17:01
gazza
hi cheers for quick response
i originally had q4os-3.6 installed and did apt-get dist-upgrade, but i also have q4os-3.7 burned onto a cd which also has the same problem. i will try to post the terminal output in due course, also maybe a video.
g
#4 2019-06-21 21:14
gazza
#5 2019-06-21 21:38
gazza wrote:
All I get is video unavailable...
#6 2019-06-21 22:52
gazza
very sorry should work now
https://youtu.be/lhm-4vqol5E
#7 2019-06-21 23:19
I tested what you did on my machine and it works as it should, so I cannot confirm an issue, is this a 32bit or 64 bit installation? and do you have the correct video drivers installed?
It might be most useful if you could install inxi and post the output of
inxi -F
this will show us some information regarding the machine specs and some driver status of your set-up.
#8 2019-06-22 00:05
gazza
System:    Host: Escape-Earth Kernel: 4.19.0-5-amd64 x86_64 bits: 64 Desktop: Trinity R14.0.6 Distro: Q4OS 3.7.1-n1
Machine:   Type: Laptop System: Hewlett-Packard product: HP Pavilion g7 Notebook PC v: 0593110000204610000620100
           serial: <root required>
           Mobo: Hewlett-Packard model: 1664 v: 20.24 serial: <root required> BIOS: Insyde v: F.6A date: 05/07/2013
CPU:       Topology: Quad Core model: AMD Phenom II P960 bits: 64 type: MCP L2 cache: 2048 KiB
           Speed: 800 MHz min/max: 800/1800 MHz Core speeds (MHz): 1: 800 2: 800 3: 800 4: 800
Graphics:  Device-1: Advanced Micro Devices [AMD/ATI] RS880M [Mobility Radeon HD 4225/4250] driver: radeon v: kernel
           Display: tty server: X.Org 1.20.4 driver: ati,radeon unloaded: fbdev,modesetting,vesa resolution: 1600x900~60Hz
           OpenGL: renderer: AMD RS880 (DRM 2.50.0 / 4.19.0-5-amd64 LLVM 7.0.1) v: 3.3 Mesa 18.3.6
Audio:     Device-1: Advanced Micro Devices [AMD/ATI] SBx00 Azalia driver: snd_hda_intel
           Device-2: Advanced Micro Devices [AMD/ATI] RS880 HDMI Audio [Radeon HD 4200 Series] driver: snd_hda_intel
           Sound Server: ALSA v: k4.19.0-5-amd64
Drives:    Local Storage: total: 256.17 GiB used: 15.36 GiB (6.0%)
           ID-1: /dev/sda vendor: Crucial model: CT275MX300SSD1 size: 256.17 GiB
Partition: ID-1: / size: 39.37 GiB used: 15.36 GiB (39.0%) fs: ext2 dev: /dev/sda1
Sensors:   System Temperatures: cpu: 72.5 C mobo: N/A
           Fan Speeds (RPM): N/A
Info:      Processes: 178 Uptime: 6h 20m Memory: 3.60 GiB used: 1.02 GiB (28.4%) Shell: bash inxi: 3.0.32
#9 2019-06-22 09:26
@gazza
Thanks for the detailed reporting. As we are not able to reproduce this issue, we would need some more debugging on your side.
1. Please reboot the machine and run in terminal:
$ dcop kicker kicker restart
panel should be restarted. Report back, if that went properly. Next, run another commands:
$ dcop kicker kicker quit
$ /opt/trinity/bin/kicker
$ dcop kicker kicker configure
$ dcop kicker SystemTrayApplet iconSizeChanged
again, report back how it bears.
2. What is the error message printed on the terminal ? It's not readable from video.
EDIT:
3. How is terminal connected to the panel issue ?
#10 2019-06-22 09:32
I noticed your display is tty server, this makes me think it is not a "standard" installation or it is on another machine and you are using ssh to access it, or maybe in a VM? My systems always show something like :
Display: x11 server: X.Org 1.20.4
Have you installed other desktop environments?
One more thing i noticed is that your desktop in the video looks very "Scorpion" and I was wondering if you upgraded Scorpion to Centaurus?
If so then I would imagine this to be the problem as it is not a recommended approach, it could still be recoverable but it would need a better understanding of Trinity than I have...
cool Pro tip: Using code boxes with terminal output makes it easier to read.
#11 2019-06-22 15:35
gazza
hi q4os team and dai_trying
thanks for helping me out
as i said in my original post from boot the colours dont load correctly, so i come out of vt-7 without logging in, and log into vt-1(then startx). doing this makes the colours correct.
i have customised the os a little, and so if the glitch is not reproducible by you two then it's definitely me.
i have been running this same system for a while, so a fresh install is probably going to be easier and better in the long term. i will lose all my settings unfortunately sad
thanks once again
gaz
#12 2019-06-22 17:32
I have to admit I tend not to adjust much on any distro I use, I stick to the default layout and colours and if I cannot use it I change distro, but there is a lot that can be customised without any compromise to the system I just prefer to keep things as simple as possible.
I do like the Centaurus appearance ootb, and I had grown used to Scorpion too, but I always change the background wallpaper which can make the whole desktop lighter/darker to my preference.
#13 2019-06-22 19:28
gazza
i'm quite the opposite, i have to have things the way i like them. cool avatar BTW, is it a family coat of arms ?
#14 2019-06-22 19:45
No, my local Rugby club. I always seem to remove a lot of software when I install a distro, that's my area of OCD smile much easier with Q4OS (IMO)
#15 2019-06-22 20:04
gazza
i do the same, leaner is better.
"my local rugby club" i feel like a right plonker, who has a "family coat of arms" now a day's !!
#16 2019-06-22 20:07
gazza wrote:
... from boot the colours dont load correctly ...
We are trying to reproduce that, but still no success. Would you provide some instructions how to reproduce such a quite serious bug, please ?
#17 2019-06-22 20:16
gazza
sorry Q4os team for wasting your time it must just be my machine.  as i said, i have altered the system from "stock", so i'll just fresh install.
thanks for such good support
#18 2019-06-22 20:21
Well, if you will figure out how to reproduce that on another hardware, we would appreciate, if you post it here. Anyway, thanks for reporting smile
#19 2019-06-22 20:28
gazza
no problem, i will soon delete this system before i fresh install. if you would like me to give you any type of info/settings data etc etc then let me know, and i will try.
please be aware i'm an amateur.
