#1 2019-04-17 09:02
pcpro
Make desktop look like Windows
I looked at the Tutorias
I wanted to try make-your-desktop-look-like-windows
But I can not find setup_xpq4_2.1-a1_all.esh
I checked the Themes out, but the Windows lokkalike themes are not there
#2 2019-04-17 12:22
Marcus
Re: Make desktop look like Windows
It's not part of the official distribution but a side project. You have to download the installer from here: https://xpq4.sourceforge.io/
#3 2019-04-18 09:17
pcpro
How do I add shortcuts to the task bar?
Can the login box also be themed ?
#4 2019-04-22 09:08
To add shortcuts to the taskbar - right click the taskbar>unlock panels
Then right click>add application>browse to required item
After you're done right click and lock panel.
See http://www.q4os.org/forum/viewtopic.php?id=2629 for a reply on the subject of the login box
