#1 2018-04-20 06:52
Master PDF Editor
Like many applications with a linux port this has a basic free version or you can pay for a full version.
https://code-industry.net/free-pdf-editor/
There are 3 download options.
The Ubuntu 32 bit 12-14 i386 will install under Orion with the addition of a hundred plus i386 files.
The Ubuntu 64 bit 12-14 package is a static binary and works without any additional files under Orion
The Ubuntu 64 bit 14-18 package will not install in Orion as it requires some qt5 libs - it may works with Scorpion
My needs are fairly simple in terms of sanitizing pdf files of personal data before making them available for public download and it works a treat - definitely nicer to use than Libreoffice which has been given the boot!
#2 2018-04-20 07:38
Re: Master PDF Editor
I just installed it and it certainly seems like it will fit my need more than adequately too! Nice find bin and thanks for posting it, the last time I searched for a Linux pdf editor I couldn't find anything that actually worked like I wanted it to. smile
#3 2018-06-06 06:29
witloof
Beware ................
The version 5.2.02 now prints a watermark "Created by Master PDF Editor" diagonally across the page when the previous (4.xx) version did not.
If you want to remove the watermark......pay up !
#4 2018-11-14 03:35
gnobody
Seems there's some important features missing from the Master PDF Editor.
- No owner password protection to prevent further changes to PDF file/s
- No user password to open a PDF
- Custom stamps are very basic and clunky.  Difficult to add your personal signature as a stamp.
There's sure to be other issues.  I only just got started, but already decided to look for better alternative product.
YMMV
#5 2018-11-14 07:00
YMMV
That's funny - I just click File>Properties>Security>Password Encryption to set a password that has to be used to open the file.
Not sure what your problem is with Stamps - seems fine to me
Have you got your Qt settings configured properly???
#6 2019-01-26 22:02
sickpig
masterpdf didn't work on my machine
foxit did and has the same features of adobe reader, even better in some aspects
#7 2019-02-01 11:24
Curious.
Just installed my old 4.389 qt5 version and it's OK on Scorpion. Not tried the latest for obvious reasons smile
#8 2019-02-01 17:49
sickpig
Not sure y it didn't work and I did not pursue since I got a working pdf reader/ annotater in the form of foxit
#9 2019-02-11 15:09
debiandonder
Okular works the best on my pc and it looks great too.
#10 2020-08-20 15:51
sahrenity
It works well but it's too complicated for me. I'm so bad at pdf editing so I'm looking for something more user-friendly.
#11 2020-08-21 14:33
blowyourbrain
Try free online editors and chose the best one for your needs.
