#1 2019-01-26 22:49
paulus
MEGAsync does not load at startup [SOLVED]
Hi all,
I installed the MEGA sync app for my MEGA folder, in order to automatically download and upload files to the cloud in that folder. The sync app was found on the site of MEGA, and does actually work.
But after a fresh start of Q4OS it does not show up in the panel: after investigation it appeared that it did not start. Of course I can start the sync app manually, but it has to be started by its own.
Question 1: How could I make it work that it is started each time I start Q4OS?
Question 2: Where can I see all my startup apps, the place where I could add the MEGA sync app, in case I have to add it manually to that place? By the way: it is also good to know where I could add startup apps or programs I want to have started right at the beginning of a Q4OS-session.
Thanks in advance; kind regards,
paulus
#2 2019-01-28 11:44
paulus
Re: MEGAsync does not load at startup [SOLVED]
Hi all,
I finally found out how to do it: in the FAQ-section I read in "4.6. How can I autostart an application?" how to do it.
Cheers,
paulus
