#1 2018-11-18 15:13
jschall
Conky - How to display Pinebook battery?
I'm running TDE on Q4OS on my Pinebook 1080p.
I would like to add a battery monitor to my conky.
I have tried ${battery BAT0} and ${battery BAT1}, but neither produce any display.
What am I missing?
#2 2018-11-19 11:24
Re: Conky - How to display Pinebook battery?
Can you check if you have the right info on your system? you could try this command and it should give you the current percentage of your battery
cat /sys/class/power_supply/BAT0/capacity
This should simply output a number between 0 and 100 (the percentage of battery remaining).
If you get a "No such file or directory" error could you post her the output of
ls /sys/class/power_supply/
#3 2018-11-19 12:58
jschall
Thank you for the reply, @Dai_trying.
That command does output the same percent as the little widget on the panel.
I have used it in a script on the top line of my conky:
${exec  /.battery_percent}%
I'd prefer a built-in conky command and a bar graph if possible.
adminq@pinebook1080p:~$ ls /sys/class/power_supply/
ac  battery  usb
#4 2018-11-19 14:04
can you start the conky from the command line using your custom file (if necessary) using ${battery BAT0} so we can see if any error is output
conky -c .my_conkyrc
replacing .my_conkyrc with your custom file (if used)
or if you are using .conkyrc in your home folder simply issuing conky as a command would have the same effect.
please post any output
#5 2018-11-19 16:44
jschall
Do you mean:
adminq@pinebook1080p:~$ conky&
[1] 20708
adminq@pinebook1080p:~$ conky: desktop window (1200016) is subwindow of root window (25d)
conky: window type - normal
conky: drawing to created window (0x3800002)
conky: drawing to double buffer
*** Error in `conky': corrupted size vs. prev_size: 0x000000558dafec70 ***
#6 2018-11-19 17:57
I have requested your wifilevel script in the other post but I think the problem is the same here, comment out the wifilevel script and put ${battery BAT0} in place of your battery level script to see if that works.
#7 2018-11-19 19:31
jschall
Thanks for looking into my problem, @Dai_trying.
Here is what happens when I replace ${exec ./batt_percent} with ${battery BAT0}:
adminq@pinebook1080p:~$ killall conky
[1] 22726
conky: can't open /sys/class/power_supply/BAT0/uevent: No such file or directory
conky: can't open /proc/acpi/battery/BAT0/state: No such file or directory
conky: can't open /proc/apm: No such file or directory
*** Error in `conky': corrupted size vs. prev_size: 0x000000557271c6d0 ***
^C
[1]+  Aborted                 conky
#8 2018-11-19 20:04
do you get information when using the following command?
cat /sys/class/power_supply/BAT0/uevent
If not could you post the output of
ls -l /sys/class/power_supply/BAT0/
#9 2018-11-19 21:20
jschall
Here ya go:
adminq@pinebook1080p:~$ cat /sys/class/power_supply/BAT0/uevent
cat: /sys/class/power_supply/BAT0/uevent: No such file or directory
adminq@pinebook1080p:~$ ls -l /sys/class/power_supply/BAT0/
ls: cannot access '/sys/class/power_supply/BAT0/': No such file or directory
adminq@pinebook1080p:~$ ^C
I really appreciate your help, @Dai_trying.
#10 2018-11-19 22:48
This doesn't make sense, your reply in post #3 says you issued the command cat /sys/class/power_supply/BAT0/capacity and it produced an output matching your toolbar display but now the same path is not available...???...
it seems you did not execute the command exactly as I posted it but adapted it...
double checking that post you showed the battery listed as battery and not BAT0, maybe you could use ${battery battery} in your conky but I don't know if that will work but it should...
#11 2018-11-20 02:15
jschall
This is the script that works:
#!/bin/sh
cat /sys/class/power_supply/battery/capacity
So, it seems that "battery" has replaced "BAT0" everywhere?
#12 2018-11-20 10:19
yes it looks that way, did you try it in conky? and did it work?
#13 2018-11-20 13:20
jschall
Well, ${battery battery} sort of works. It gives a weird negative percent.
But my conky still keeps crashing, as you can see in the screenshot.
#14 2018-11-20 14:30
This is definitely a bit weird... unfortunately I do not have any similar hardware to be able to test so not sure I can offer any more advice really...
One thing you could try is to comment out all lines in the text section and then un-comment 1 line at a time to see where the problem starts, this is what I would do to narrow down where any problem(s) is (are).
#15 2018-11-25 22:35
jschall
I finally have a workaround that displays the battery percentage and status in Conkyon my Pinebook.
I use the shell commands in script files:
#!/bin/sh
and
#!/bin/sh
cat /sys/class/power_supply/battery/status
and I just use two ${exec ./ } commands on a line in .conkyrc
It may not be elegant, but it works.
