#1 2018-10-12 19:05
system5
Headset with Microphone Recommendations
I am looking to purchase a headset with microphone but the ones I am looking at tend to state that they are compatible with Windows but do not seem to mention Linux.
With this in mind, I shall be grateful for any recommendations for headsets that are compatible with Q4OS.
#2 2018-10-12 20:21
Re: Headset with Microphone Recommendations
I have a logitech one (h390 I think?) that works GREAT.  Was fairly cheap for a USB headset, stereo with an adjustable boom microphone.  I use it for conference calls at work mostly when I'm working from home.
#3 2018-10-12 20:56
system5
Sounds like a good choice although I may just end up purchasing  a USB microphone.
Did the headset work out of the box without the need to locate and install any drivers because when I reviewed the system requirements there was no mention of linux?
#4 2018-10-15 17:20
It did on all the installations I've used it on.  Immediately seen as a multimedia device and just changed the pulse settings to use it as the default for speaker & mic.
