#1 2018-09-18 16:52
cpcnw
Q4OS on Minix Neo Z64-W
Hi All,
Yes, so for a minute there I couldn't backspace. I have now edited /etc/default/keyboard and that seems to be working.
Anyway, bought one of these [subject] device cheap offa ebay and have managed to get Q4OS installed. I had to use an older firmware for Android. I then cleared the eMMC and used the live installer from an external USB card reader / sd card.
All has gone pretty well apart from the following;
No sound sad
No wi-fi sad
I found this post http://www.linuxium.com.au/how-tos/mini … dioandwifi but am not sure how much of it is relevant in my case?
Could someone with more driver skills comment?
Tia!
#2 2018-09-18 16:54
Re: Q4OS on Minix Neo Z64-W
cpcnw wrote:
Hi All,
Hi smile
#3 2018-09-18 17:21
cpcnw
Dai_trying wrote:
cpcnw wrote:
Hi All,
Hi smile
Can now edit posts - yoohoo!
#4 2018-09-18 17:43
cpcnw
#5 2018-09-18 19:33
If you have cable networking you could install inxi and post the output of inxi -F as the spec sheet doesn't show any specifics for wifi or sound chip.
#6 2018-09-18 20:20
cpcnw
Looking at the script in that link it looks like the Wi-Fi is r8723bs
gbentley@minix:~/audio-wifi-minix-neo-z64.release$ sudo insmod r8723bs.ko
insmod: ERROR: could not insert module r8723bs.ko: Invalid module format
gbentley@minix:~/audio-wifi-minix-neo-z64.release$ sudo modinfo r8723bs.ko
filename:       /home/gbentley/audio-wifi-minix-neo-z64.release/r8723bs.ko
version:        v4.3.5.5_12290.20140916_BTCOEX20140507-4E40
author:         Realtek Semiconductor Corp.
description:    Realtek Wireless Lan Driver
license:        GPL
srcversion:     968F3D17D4C6C51C9E84513
alias:          sdio:c*v024Cd0623*
alias:          sdio:c*v024CdB723*
depends:        cfg80211
vermagic:       3.16.7-ckt3.linuxium SMP mod_unload modversions
parm:           rtw_ips_mode:The default IPS mode (int)
parm:           rtw_usb_rxagg_mode:int
parm:           rtw_btcoex_enable:Enable BT co-existence mechanism (int)
parm:           rtw_ant_num:Antenna number setting (int)
parm:           rtw_qos_opt_enable:int
parm:           ifname:The default name to allocate for first interface (charp)
parm:           if2name:The default name to allocate for second interface (charp)
parm:           rtw_initmac:charp
parm:           rtw_channel_plan:int
parm:           rtw_chip_version:int
parm:           rtw_rfintfs:int
parm:           rtw_lbkmode:int
parm:           rtw_network_mode:int
parm:           rtw_channel:int
parm:           rtw_mp_mode:int
parm:           rtw_wmm_enable:int
parm:           rtw_vrtl_carrier_sense:int
parm:           rtw_vcs_type:int
parm:           rtw_busy_thresh:int
parm:           rtw_ht_enable:int
parm:           rtw_bw_mode:int
parm:           rtw_ampdu_enable:int
parm:           rtw_rx_stbc:int
parm:           rtw_ampdu_amsdu:int
parm:           rtw_lowrate_two_xmit:int
parm:           rtw_rf_config:int
parm:           rtw_power_mgnt:int
parm:           rtw_smart_ps:int
parm:           rtw_low_power:int
parm:           rtw_wifi_spec:int
parm:           rtw_antdiv_cfg:int
parm:           rtw_antdiv_type:int
parm:           rtw_enusbss:int
parm:           rtw_hwpdn_mode:int
parm:           rtw_hwpwrp_detect:int
parm:           rtw_hw_wps_pbc:int
parm:           rtw_max_roaming_times:The max roaming times to try (uint)
parm:           rtw_mc2u_disable:int
parm:           rtw_notch_filter:0:Disable, 1:Enable, 2:Enable only for P2P (uint)
parm:           rtw_hiq_filter:0:allow all, 1:allow special, 2:deny all (uint)
parm:           rtw_tx_pwr_lmt_enable:0:Disable, 1:Enable, 2: Depend on efuse (int)
parm:           rtw_tx_pwr_by_rate:0:Disable, 1:Enable, 2: Depend on efuse (int)
parm:           rtw_phy_file_path:The path of phy parameter (charp)
parm:           rtw_load_phy_file:PHY File Bit Map (int)
parm:           rtw_decrypt_phy_file:Enable Decrypt PHY File (int)
#7 2018-09-18 20:29
cpcnw
According to this ;
http://hwswbits.blogspot.com/2015/03/ge … o-z64.html
sound chip is Realtek ALC5642
#8 2018-09-18 20:37
cpcnw
Somewhat contradicted by this teardown...
http://www.xtremesystems.org/forums/sho … -NEO-Z64-W
guess I will follow the advice above...
#9 2018-09-18 20:46
cpcnw
Hmm, inxi doesn't detect either - still probably got enough to go off already...
#10 2018-09-18 21:37
cpcnw
Did an update / upgrade etc then following
https://github.com/hadess/rtl8723bs/wik … the-module
Make and install the module
Install build support packages, note that "4.1.0-0.bpo.2" below should be replaced by the result of running "uname -r"
# apt-get install unzip build-essential linux-headers-4.1.0-0.bpo.2-all-amd64
Download the module
# cd /usr/local/src
# wget https://github.com/hadess/rtl8723bs/archive/master.zip
Make the module
# unzip master
# cd rtl8723bs-xxx
# make
Install the module
# sudo make install
# sudo depmod -a
# sudo modprobe r8723bs
which all goes very well until the last command...
gbentley@minix:/usr/local/src/rtl8723bs-master$ sudo modprobe r8723bs
modprobe: FATAL: Module r8723bs not found in directory /lib/modules/4.9.0-8-amd6
so tried
# sudo modprobe rtl8723bs
with the same result. Looking in /lib/modules/4.9.0-8-amd64/kernel/drivers/net/wireless/realtek/rtlwifi/ there is no r8723bs folder?
And I can't find any corresponding .ko file using find?
#11 2018-09-18 21:50
cpcnw
The makefile states the following
install:
	@mkdir -p /lib/firmware/rtlwifi/
	@cp -n rtl8723bs_nic.bin /lib/firmware/rtlwifi/rtl8723bs_nic.bin
	@cp -n rtl8723bs_wowlan.bin /lib/firmware/rtlwifi/rtl8723bs_wowlan.bin
and those two files do exist in the specified directory!
#12 2018-09-19 09:44
I just tried installing this and got the same results as you did, that is the files mentioned in the Makefile are copied to the stated location but there are no source files! it looks like this simply copies the two files and nothing more???? maybe not the best driver to use?
According to this page the device should be available from kernel 4.12 onwards, so maybe the best bet would be to install the kernel from backorts and with a little luck it should just fire up. I'll keep my fingers crossed for you. smile
#13 2018-09-19 10:06
@cpcnw
You could use the 'qinst-kernel-bpo' script to install kernel from backports, it will take care of the needed steps. Just run as a user:
$ qinst-kernel-bpo
You will need to edit the '/etc/apt/sources.list.d/30_debian_backports.list' file and enable backports repository first.
#14 2018-09-19 13:44
cpcnw
Following above this step succeeded # sudo modprobe rtl8723bs
However, whilst TDE Network Manager correctly identifies mine and my neighbours SSID's when I setup a connection with password it fails with 'unable to find SSID' or something similar sad
Edit: hang on, its working?! That was odd. When I put the Ethernet jack back in, then  edited the wireless connection to make sure I had everything right [I did] I got a tick against it. Then I pulled out the Ethernet and the Wi-Fi started working!?
Even odder - when I first set it up it said signal strength 92% (I'm right next to it!) but now I am actually connected its only 32%?
Anyway, it works! Would it be worth me posting the .ko anywhere?
Also, any tips on getting sound working?
Thanks!
smile
#15 2018-09-19 13:56
Did you try to follow this one ? https://q4os.org/dqa011.html#install.3
#16 2018-09-19 14:29
cpcnw
Just now yes - no luck though sad
KMix windows is huge and wont downsize?
#17 2018-09-19 14:35
try kmix-trinity
#18 2018-09-19 14:44
cpcnw
Mean that really smile
#19 2018-09-19 14:54
I didn't think that would be a large download...
#20 2018-09-19 15:05
cpcnw
Sorry I meant the kmix wondow is covering over half the screen and doesn't resize using the grab handles!
#21 2018-09-19 15:43
Sorry, I understand now, I did have a similar issue with Qt screen sizing and noticed it first with VLC but it might also help with your situation, add
QT_AUTO_SCREEN_SCALE_FACTOR=0
to the file /etc/environment
