Is it possible to upgrade Q4OS 2.4 to Q4OS 2.5 without reinstalling whole system ? I would keep Trinity desktop without installing KDE Plasma 5.8 LTS. I have un very old portable and Q4OS is fine for this old computer. I don't know if it is interresting for me to upgrade to 2.5.
If yes, is it possible to upgrade with command lines in the terminal ? in mode superuser ?
Many thanks and sorry for my poor english (I am french...).
Harry
Hi Harry, you should be fine to update to Version 2.5 in the usual update manner, you will not be forced to install Plasma or anything else as it is totally optional. And updating as superuser is as simple as
apt update && apt upgradeThere may be one or two subtle differences in the system by upgrading rather than re-installing but it is likely not noticeable.
Yes, it is. Automatic updates will take care about 2.4 -> 2.5 upgrade, you don't need to do anything. If you have disabled automatic upgrades, you can trigger the update manually using Synaptic package manager or from terminal:
$ sudo apt update
$ sudo apt dist-upgrade
Don't worry about that, Plasma desktop will not be installed, unless you explicitly ask to install it.
Yes, we would recommend you to upgrade, please see answers above.
Posted in the same minute! ![]()
@Dai_trying
Even in the same second, as we have checked a possible answer, next paste + click to post, refresh immediately and both posts were already here ![]()
@Harry
You can check the current Q4OS version in terminal:
$ get-q4os-version
Many thanks to Dai_trying and q4os Team for your prompt replies.
I have checked my current version in terminal and the reply is : 2.5.1-n1
I have updated some files this morning and I think that the updater has installed the last version.
Do I have to do another thing ?
Thanks
Harry
You're welcome, everything looks like it is updated for you, so you should be ok. ![]()
Hi,
You say "Plasma desktop will not be installed, unless you explicitly ask to install it"
How do you explicitly ask to install it?
I am keen to try it, thanks.
Hi,
Q4OS Software centre > Desktop profiler > click 'Desktop environment' button > check 'Yes, I really want to install additional DE' > select 'KDE Plasma' from combobox > Ok > select a desktop profile > click 'Install' button
It gets to certain point then stalls.
Below is the last bit of the output:
W: GPG error: http://ppa.launchpad.net/libreoffice/ppa/ubuntu cosmic InRelease: The following signatures couldn't be verified because the public key is not available: NO_PUBKEY 83FBA1751378B444
W: The repository 'http://ppa.launchpad.net/libreoffice/ppa/ubuntu cosmic InRelease' is not signed.
N: Data from such a repository can't be authenticated and is therefore potentially dangerous to use.
N: See apt-secure(8) manpage for repository creation and user configuration details.
W: GPG error: http://ppa.launchpad.net/teejee2008/ppa/ubuntu bionic InRelease: The following signatures couldn't be verified because the public key is not available: NO_PUBKEY B5B116B72D0F61F0
W: The repository 'http://ppa.launchpad.net/teejee2008/ppa/ubuntu bionic InRelease' is not signed.
W: GPG error: http://ppa.launchpad.net/webupd8team/java/ubuntu bionic InRelease: The following signatures couldn't be verified because the public key is not available: NO_PUBKEY C2518248EEA14886
W: The repository 'http://ppa.launchpad.net/webupd8team/java/ubuntu bionic InRelease' is not signed.
Reading package lists... 100%
Reading package lists... Done
Building dependency tree
Reading state information... 0%
Some packages could not be installed. This may mean that you have
requested an impossible situation or if you are using the unstable
distribution that some required packages have not yet been created
or been moved out of Incoming.
The following information may help to resolve the situation:
q4os-libreoffice : Depends: libreoffice-ogltrans but it is not going to be installed
Depends: libreoffice-kde but it is not going to be installed or
libreoffice-gtk3 (>= 6.0) but it is not going to be installed
Depends: libreoffice-style-breeze but it is not going to be installed
Depends: libreoffice but it is not going to be installed
E: Unable to correct problems, you have held broken packages.
Well I am not sure what happened but when I rebooted KDE desktop was installed so it seems all is well.
Except now I cant install Libreoffice, it says I have broken packages.
@Jedi
You have added a few alien repositories into your system, for ex.:
http://ppa.launchpad.net/webupd8team/java/ubuntu bionicIt's not recommended and most likely results in broken packages dependencies. We would recommend you to remove such repositories and run fix script, please see https://q4os.org/dqa011.html#system.1
How do I remove the repositories?
You can check if they exist in the file /etc/apt/sources.list and if so remove them (you can simply delete this file if it only contains these entries)
If they are not (all) in this file you should look in the folder /etc/apt/sources.list.d/ and find any files that contain these entries and remove them. It is difficult to give more precise information as we do not know how you added these sources in the first place. Hope this helps.
Once they are all removed you should run sudo apt update to refresh your apt db information, then you should run the procedure posted by the Dev Team
Happy to report Libre Office has successfully installed :-)
