#1 2018-06-03 03:47
pbrahim
Auto Wireless Connection
i have a problem with network connectivity i need each time i log in to click on my wireless connection to connect is there a way to automate this process and make the connection automatic  once i log in ? Thanks smile
#2 2018-06-03 08:31
Re: Auto Wireless Connection
You probably need to setup the connection as "Autoconnect". Click to the networkmanager icon in systray > Edit Connections > select your wireless connection > click Edit Connection > Next > Next > check Autoconnect box > Save
#3 2018-06-03 16:22
system5
I do not have exactly the same problem but for some reason, although I believe that my network adaptor is working, Network Manager seems unable to find any networks. I was connected to the internet without any problem this morning but when I rebooted my system this problem has emerged. Has anybody experienced the same problem? Should I reinstall Network Manager?
#4 2018-06-03 16:44
@system5
You could try to connect using "nmtui" tool - a simple NetworkManager text user interface. Just run it in terminal:
$ nmtui
try to make a connection and report back.
#5 2018-06-03 18:12
system5
I used the "nmtui" tool and could see all available networks including my own. I activated my connection successfully and was using Network Manager to make sure that it was set to auto connect when the connection disconnected. I tried the "nmtui" tool again but have not been able to activate the connection for a second time as Network Manager returns the message "ssid not found". It seem that the problem is with Network Manager but I would welcome your further advice.
#6 2018-06-03 21:48
It could be a problem with your firmware, what device are you using?
I have had to install firmware from github for a RTL8192cu which had the same issue (connection drops after a short while)
#7 2018-06-07 07:00
system5
I am using a TP-Link Dual Band Wireless Adaptor and the good news is that after reactivating the connection with the "nmtui" tool it appears that I just needed to reboot my system. When I loaded up my system again the following morning everything was back to normal and the connection has remained stable. Thank you both for your advice.
#8 2018-06-07 07:15
You are welcome, and I'm glad to hear it is working properly now smile
