#1 2018-05-12 13:09
bosstronpie
Q4OS Windows installer not opening in Windows 7
I downloaded the installer of chrome and opened it and it wont open, it shows run as adminstrator part, I press ok but then nothing else happens, I tried different ways of opening it but it wont open. Please help.
#2 2018-05-12 13:14
bosstronpie
Re: Q4OS Windows installer not opening in Windows 7
Just to clear stuff its not a chrome installer, I downloaded the Q4OS Windows installer on my chrome browser in Windows 7
#3 2018-05-12 16:15
I haven't tried an installation on Windows 7, but you could check out my installer guide although I used Windows 10 but the basics are the same, I don't think you need to "run as Administrator" just double click the file from your file manager.
#4 2018-05-13 09:48
bosstronpie
Thing is, it downloads it as a file that has that run as administrator so even if I dont right click and run as adminstrator, its a setup file that comes with the run as adminstrator so how can I take it off?
#5 2018-05-13 14:45
Can't you just navigate to the file in your file manager and double click it?
#6 2018-05-22 18:41
BrJPedro
bosstronpie, you can try to use the "Fix compatibility problems" (or something like this, my Windows installation is not in English) option in context menu (right-click) of Windows. Then choose "Try recommended settings" option.
