#1 2018-03-05 21:24
24past
Repository is not signed
Hi,..
It is my first post, i already use q4os from orion. when i try scorpion, and want to install synaptic in software center. i have this error massage
Reading package lists... Done
W: The repository 'http://ftp*debian*org/debian stretch Release' is not signed.
N: Data from such a repository can't be authenticated and is therefore potentially dangerous to use.
N: See apt-secure(8) manpage for repository creation and user configuration details.
E: Failed to fetch http://ftp*debian*org/debian/dists/stretch-updates/main/i18n/Translation-en 502 Bad Gateway [IP: 130.89.148.12 80]
E: Failed to fetch http://ftp*debian*org/debian/dists/stretch/main/i18n/Translation-en 502 Bad Gateway [IP: 130.89.148.12 80]
E: Failed to fetch http://security*debian*org/debian-security/dists/stretch/updates/contrib/i18n/Translation-en 502 Bad Gateway [IP: 151.101.8.204 80]
E: Some index files failed to download. They have been ignored, or old ones used instead.
Update sw database ... Done
Testing installation ...
Reading package lists... 100%
Building dependency tree
Reading state information... 0%
Some packages could not be installed. This may mean that you have
requested an impossible situation or if you are using the unstable
distribution that some required packages have not yet been created
or been moved out of Incoming.
The following information may help to resolve the situation:
synaptic-q4 : Depends: gdebi-core but it is not installable
Depends: synaptic-trinity but it is not going to be installed
Depends: synaptic but it is not installable
E: Unable to correct problems, you have held broken packages.
Testing installation ... Done
i try sudo apt-get update and get this error massage
How to fix this error? Sorry for my bad english, its not my native language. And thank before smile
#2 2018-03-05 21:43
Re: Repository is not signed
Hi, and welcome to the forum, could you post the output of
qrepolist
#3 2018-03-05 22:44
24past
this is the output of qrepolist
deb http://q4os*org/q4repo q4os-2-0-cn main
deb http://q4os*org/qtderepo stretch main
deb http://ftp*debian*org/debian/ stretch main contrib non-free
deb http://security*debian*org/debian-security/ stretch/updates main contrib non-free
deb http://ftp*debian*org/debian/ stretch-updates main contrib non-free
deb [arch=amd64] http://dl*google*com/linux/chrome/deb/ stable main
#4 2018-03-05 22:54
I am guessing that there could be a language problem here (with the computer, not the user smile ) as the output you have given shows an asterisk (*) where there should be a quote ("). I would try changing all the asterisks to quotes and see if that fixes the problem.
#5 2018-03-05 22:59
24past
no,.. its a dot ( . ) i cant post link or maybe i can with url tag but im too lazy to make a tag so i change that dot to asterisk
#6 2018-03-05 23:13
I can post mine without issue here, can you select the text in the terminal and copy it , then in your browser just paste it to make sure we get the correct data.
deb http://q4os.org/q4repo q4os-2-0-cn main
deb http://q4os.org/qtderepo stretch main
deb http://ftp.debian.org/debian/ stretch main contrib non-free
deb http://security.debian.org/debian-security/ stretch/updates main contrib non-free
deb http://ftp.debian.org/debian/ stretch-updates main contrib non-free
deb http://ftp.debian.org/debian/ stretch-backports main contrib non-free
If the problem is because you cannot post links yet you can paste the information into a code box and it will be much clearer to us.
But after deciphering your post I can see that is not really the issue here...
#7 2018-03-05 23:17
24past
here is my qrepolist
deb [arch=amd64] http://dl.google.com/linux/chrome/deb/ stable main
#8 2018-03-05 23:27
24past
i think this is my problem. it is a fresh install Q4OS and none software installed. I cant install any, even desktop profiler because of this error. and ive done reinstalled Q4OS 3 times, but the problem still exist.
#9 2018-03-05 23:33
This has me baffled as I checked the IP address for the ftp site and your output is showing as correct.
I can see that the error says bad gateway, could this be a dns problem?
I have done 3 installs of Q4OS Scorpion in the last week and have not had any problems installing or updating...
Did you check the md5sum of the image you used before writing it to your installation media?
#10 2018-03-06 08:24
@24past
We are not able to reproduce this glitch, updates work fine here. We are guessing it's a kind of a local network configuration issue.
#11 2018-03-06 15:12
@24past - please could you confirm how you installed Scorpion? Have you by any chance just added the Scorpion Repos to Orion?
