#1 2018-02-20 16:24
crossworx
opera browser
first will Q4OS run Opera? If so how do I install it? I have downloaded it but do not know what to do next.
If I can't run it how do I update Chrome? I have downloaded it too but do not understand the process to load it.
#2 2018-02-20 16:31
Re: opera browser
You can Chrome (or Chromium) from the Q4OS Software Centre, no need to mess about with deb files or downloads.
EDIT:
You can enable Opera repository by typing into a terminal the following:
sudo qrepoadd --gui
select opera and click ok. When that has finished open a terminal and type
sudo apt update
followed by
sudo apt install opera
#3 2018-02-20 17:47
crossworx
Re: opera browser
i will try, thanks so much
well i am a complete beginner and didnt even know how to get to the terminal
I thought it was the command box when I click start, anyway a complete newbie sorry
#4 2018-02-20 18:11
Re: opera browser
You are welcome smile
#5 2018-02-20 19:15
UAOS
Re: opera browser
Yes Opera will run in Q4OS.
1. open konsole
2. change to the folder downloaded to by typing in this command:
    this command is upper/lower case sensitive
    my user name is adminq, you would replace that with yours
    Amusing the folder your download the deb file is in "Download"
     cd /home/adminq/Download
3. use dpkg to install the deb file by typing
sudo dpkg -i opera-stable_50.0.2762.58_amd64.deb
sudo in needed to run dpkg as root
dpkg command to install deb files
the -i is to install
last is the name of the deb file, in this case opera-stable_50.0.2762.58_amd64.deb
good luck, have fun
A home Linux user who believes that Linux is the future.
#6 2018-02-20 20:36
Re: opera browser
That method will also work,but I prefer to use a distro specific way to install things where possible as it makes it easier for the developers to identify problems if they arise, but that's the good thing, you have a choice. smile
#7 2018-02-20 22:27
crossworx
Re: opera browser
#8 2018-02-20 22:31
Re: opera browser
You can get to the terminal by clicking on Start -> Programs -> Konsole or depending on the menu style you have you might be able to type konsole in the search bar of the menu (if it has one).
#9 2018-02-21 20:48
crossworx
Re: opera browser
will give that a go thanks.
#10 2018-02-23 17:04
crossworx
Re: opera browser
so i found the terminal and ran through the commands and not sure what was to happen
#11 2018-02-23 20:46
crossworx
Re: opera browser
i got it,,, thanks so much!!!!
#12 2018-02-24 11:19
Re: opera browser
You're welcome smile
#13 2018-09-20 01:38
danielson
Re: opera browser
A bit late in the game but this is the message i get:
$ sudo apt install opera
Reading package lists... Done
Building dependency tree
Package opera is not available, but is referred to by another package.
This may mean that the package is missing, has been obsoleted, or
is only available from another source
E: Package 'opera' has no installation candidate
DELL Optiplex 7060 - 8G RAM.
#14 2018-09-20 07:29
Re: opera browser
You need to follow instructions above https://www.q4os.org/forum/viewtopic.ph … 090#p12090, so install using commands:
$ sudo qrepoadd --gui
select opera and click ok. When that has finished open a terminal and run:
$ sudo apt update
$ sudo apt install opera-stable
We have tested the instructions on a 64bit system and worked fine. If you still encounter issues, please post here.
#15 2018-09-20 11:30
danielson
Re: opera browser
That's what i did.
Tried a direct download from Opera, that didn't work.
So, then, after remembering to install gdebi (i have a memory of a gnat) downloaded file again from Opera and it worked.
Why it wouldn't before (even after installing gdebi) and why your threefold step tip didn't either, i don't know why.
But it works now.
#16 2018-09-20 11:34
Re: opera browser
The command was incorrect:
You needed to type instead:
#17 2018-09-20 13:29
danielson
Re: opera browser
Will try to keep that in mind if i have to re-install the distro again.
Thank you!
#18 2018-09-20 19:25
DorianDotSlash
Re: opera browser
Also if searching for packages in the terminal, you can also run;
apt-cache search opera
And all results with opera in it will be listed, including opera-stable.  Be aware that depending on the term used, you may get a LOT of results.  For example, if you search "kde", you'll get thousands of results.
Another trick is to type "sudo apt install opera" and press TAB.  This will list package names that start with "opera" instead of just containing opera somewhere in the package name or description.  You'll get far fewer options, and are more likely to find what you're looking for this way.
#19 2018-09-21 00:27
danielson
Re: opera browser
You guys are going to make a Linux geek out of me yet!
This is the 1st time i really feel that Windows 10 is going to be farther and farther away from my visual contact.
