#1 2018-02-08 20:17
rafaelramos
DOSBOX Closing When Try Run a Game
Good afternoon,
Has anyone used DOSBOX on Q4OS to play old DOS games?
I installed DOSBOX through the package manager, I mounted a "C:" drive with a folder with DOS games and when I try to open any of them, the DOSBOX window simply closes itself without presenting any error message...
#2 2018-02-08 20:49
JimW
Re: DOSBOX Closing When Try Run a Game
You may have already thought of it, but have you tried starting doxbox from a terminal? That should echo any errors.
#3 2018-02-08 23:33
Refer to this and see if anything helps,
www.tecmint.com/dosbox-runs-old-ms-dos-games-and-programs-in-linux/
#4 2018-02-23 20:54
rafaelramos
@JimW, it was really a good idea! smile
By the terminal, after the DOSBOX close, it presented the following error message:
Exit to error: DRC64: Unhandled memory reference
And this topic has helped me: https://bugs.debian.org/cgi-bin/bugrepo … bug=857341
I uninstalled the official version of the repository, downgraded to jessie's version 0.74-4 (downloaded .deb and installed via dpkg) and it's working now!
#5 2018-02-23 21:00
You don't need to downgrade dosbox. You only need to replace 'core=auto' with 'core=normal' line in the '$HOME/.dosbox/dosbox-0.74.conf' config file.
