#1 2018-02-04 00:18
Resizing Windows
To resize an open window you hover the mouse over it's border (until the mouse-cursor changes to the appropriate icon).
But you have to be rather accurate, it seems to be required a precision of +/- 1 Pixel !
(Where) can that be configurated to a more ,fuzzy' behavior?
Thank you.
#2 2018-02-04 01:24
Re: Resizing Windows
I resize windows all the time and havent had any issues, as in having to be extremely accurate with the mouse. Thats based on my peripherals and Q4OS install so your mileage may vary.
#3 2018-02-04 08:06
Likewise - never had this issue.
In Control Panel>Appearance & Themes>Window Decorations you can alter the thickness of the Border Size.
Perhaps yous is set to Tiny but even that gives plenty of grab. If you've got a high res monitor then it may be that is what is behind the effect you are seeing.
#4 2018-02-04 16:45
Thanks bin.
Just booted into Windows and controlled it's +/- 2 pixel here - for a ,rough-mover' like me that makes a big difference. The 3-Pixel range feels somewhat... let me say complicated or over-accurate for me.
And hece it should be adjustable - imo.
The visual bordersize is just fine, but maybe i'll try to play a bit with it...
