#1 2018-01-29 15:19
Tim036
Getting Terminal to work on Q4OS Scorpion
(Hope I got the name right)
It's my first day with Q4OS, so I asked on os the support folk and they gave me a few clues which helped a lot !
I use Bash a lot so as there was no obvious route (to me) I pocked around a bit and found the command line, in the control panel and with a CTRL/T terminal arrived !
(no ikon anywhere that I could find tho....)  but it ran fine !
I installed Dolphin and it worked great !    (its a file browser)  so a few more:-
Brasero  DVD burner (a bit primitive but it downloads files K3B needs)
K3B  ( an excellent DVD burner, also can turn .WAV music files to .ogg files)
after a bit of twiddling it worked a treat.
Kate (code editor)  (best there is! in my view)
Many many people loved XP and Hate most of the other MS attempts at an operating system, so a XP lookalike is really really needed IMHO !
As the years roll on, maybe this Forum will get a 'search' facility !
Congrats to the Team that put Q4OS Scorpion together !
Tim
#2 2018-01-29 15:50
Tim036
Re: Getting Terminal to work on Q4OS Scorpion
By the way to convert a .ogg file to MP3 it can be done with this once Bash (Terminal) works ok...
sudo apt-get install soundconverter
Tim
#3 2018-01-29 15:53
jackdanielsesq
Hi Tim
Welcome - you are doing just fine - lose that CDROM before it loses you - USB/HDD/SSD etc so much better
Have fun
Regards
Jack
#4 2018-01-29 16:13
Have you installed XPQ4 yet? it is available from their website and I have a guide for install and use here.
If you use bash a lot you might want to try terminator (apt install terminator) I always use it as I can split the terminal to have multiple screens and create scripts to have multiple terminals in one and run required commands to give a custom bash for scripting/testing.
I have one I use that opens a terminal and splits the window and automatically tails some system files so I can see what is going on as I test/play.
If you want/need a desktop icon, you can simply right-click the desktop and select Create New and then select Link to Application then you can use the dialog box that appears to create a desktop link to any application/script.
I prefer ffmpeg and use this command to convert ogg files to mp3
ffmpeg -i input.ogg -vn -ar 44100 -ac 2 -ab 192k -f mp3 output.mp3
And search is available from the top menu bar smile
#5 2018-01-29 17:45
@Tim036
Welcome to Q4OS
The default terminal application in the menu is Konsole
