#1 2018-01-14 20:46
gwyz
i686-pae installation keyboard errors
I installed the i686-pae version on my non-pae Inspiron 9200 laptop.  I should start by saying my previous Lubuntu non-pae worked fine. It is simply obsolete.  With Q4OS installed, I've had trouble logging my password _after_ initial login.  During "timeout" and/or during "set autologin" my password has not been recognized.  I finally found the problem when I tried typing into the terminal.  The keyboard is typing gibberish.  Hence, rejection of my password _after_ login.  (I am writing this message from another computer)
Why is the keyboard typing gibberish _after_ login? (Note:  There is _nothing_ I can do via Terminal due to "gibberish" from keyboard).
Definition of "Gibberish":  Letters _and_ numbers, instead of _all_ letters. When it does type letters, they are correct.
"Caps" is not on.  Everything is set properly.
Huh ???
#2 2018-01-14 21:57
Re: i686-pae installation keyboard errors
You may need to turn 'NumLock' off, please see https://www.q4os.org/dqa011.html#system.2
#3 2018-01-14 22:36
gwyz
Yep.  Thank you.  I feel like a dummy for not thinking of that one, especially that I usually turn it off in the Bios settings.
I know exactly what to do now; (i.e. "as per the link you gave me").
Thanks, buddy.
#4 2018-01-17 19:13
gwyz
Dear Q4OS Team,
_Thank you_ for this "non-pae" Operating System.   You've given new life to my Dell Inspiron 9200.
I'm truly grateful!
Sincerely,
Gregg
