#1 2018-01-08 12:56
Jerome
Webcams?
I'm assuming that all webcams are pretty compatible with linux these days? I only need a cheap one and was thinking of buying this from Amazon.
#2 2018-01-08 15:03
Re: Webcams?
The only time I worry is if it looks like some sort of special driver may be needed - for example I have a USB microscope which is OK under Linux but only works 100% under Windows.
I usually look for MAC compatibility along with Vista or/and W7 - My guess is this one will work at a basic level as it does mention proprietory drivers.
#3 2018-01-08 15:23
Re: Webcams?
It does say it is NOT mac compatible which could be a sign of incompatibility...
Amazon wrote:
NOTE: Not Compatible with Mac
#4 2018-01-08 17:18
Re: Webcams?
Just buy Logitech C170!
It is 100% compatible with all modern Linuxes. Just plug in and you are ready to go! You only need PulseAudio to be installed. Works perfectly with Skype and Discord! Personally I have two of them. Works very well!
Or you can buy Logitech C270 if you want HD camera. It should be compatible with Linux too, but I haven't tested it. Do NOT buy unnamed manufacturer camera!
#5 2018-01-08 18:42
Jerome
Re: Webcams?
Thanks Rademes, the C170 is fine for my purposes.
#6 2018-01-08 21:06
Re: Webcams?
Same one I use Rademes Im a big user of Logitech products.
