Has this been patched in Scorpion or is it needed?
"Dirty COW" - CVE-2016-5195
https://access.redhat.com/security/vuln … s/DirtyCow
https://security-tracker.debian.org/tra … -2016-5195
Fixed in both Orion (based on Jessie) and Scorpion (based on Stretch)
Q4OS Trinity machine - Lenovo Xiaoxin Pro 14 2024. AMD Ryzen 7 Pro 7840HS, 32GB LPDDR5, 1TB m.2 NVMe SSD, Radeon RX780M iGP, Intel AX210 Wifi 6E + BT 5.2, 14" 2880x1800 400-nit LCD.
Check out www.lwn.net if you want to keep up on security updates for various distros including Debian.
They list security updates put out daily.
Thanks guys.
I was researching something else and saw a note to be sure that patch had been applied, so, even though I know Q4OSteam and Debian stays on top of things, I thought it wouldn't hurt to ask.![]()
Its not like Windows where you can wait quite awhile for a fix. Fixes come out very quickly and news on the changes is easy to access.
Some changes require an active role by admins/managers/operators and thats where problems crop up.
