(bug-ette)
I configured my Panel to add a few applications and remove some, change the L to R order here and there.
After this when trying to access the "Show Desktop" target, when above the target the pointer changes to a "Can't access this" icon - circle with diagonal line. The arget still works to show the desktop, and problem goes away after a reboot.
Never seen that before and Ive done a lot of installs and used Q4OS quite a bit. Ive made extensive changes in the panel and assuming the divider is all the way to the right after the last icon there shouldnt be any issues.
You have many odd occurences with your system it appears, could this also be a hardware issue of some type since a reboot clears the issue?
Maybe hardware, but it seems to me a lookup offset. The cursor icon pointer (as in software pointer) has shifted index. Could be hardware that does that, but also might not be
Are you running Q4OS on any other systems? Has it occured with those systems?
No. And therefore no.
