#1 2016-01-04 18:45
bobby
Has anyone installed Grub-Customizer on Q4OS ?
GRUB-CUSTOMIZER:
I have been unable to get the requred lib* files installed as listed in all suggested ways on various sites to use cmake.
Has anyone compiled the Grub Customizer and able to install - use on Q4OS ?
This will make it a lot easier for users to modify GRUB2 Bootmenu items.
No Longer Using Q4OS
#2 2016-01-04 19:30
Re: Has anyone installed Grub-Customizer on Q4OS ?
You could follow this howto http://www.linuxserve.com/2015/05/how-t … 06-in.html , we have successfully tested it.
#3 2016-01-05 04:03
bobby
Q4OS Team,  I tried that before I made request. The error I got was it could not find libgtkmm-3.0-dev.
??? I will try again but, will libgtkmm-2.4-dev for Wheezy work ?
Thanks,
Bobby
#4 2016-01-05 09:04
Q4OS 1 Orion is 'Debian Jessie' based, not 'Debian Wheezy'. You can easily install 'libgtkmm-3.0-dev' package in Q4OS 1 Orion.
$ sudo apt-get install libgtkmm-3.0-dev
We have tested the procedure above with no issues at all.
#5 2016-01-06 11:17
Seeker
Is there a way to "make .deb package after comply in return" without  "make install"?
#6 2016-01-06 11:45
Yes, using Q4OS development pack or 'checkinstall' command.
$ sudo apt-get install checkinstall
$ man checkinstall
#7 2016-01-06 12:32
Seeker
$ man checkinstall
Thank you, I want to contribute giving deb packages in return. big_smile
