Yes, I thought I had that fixed... what version are you using?
V 0.1.20 take in that post of the forum...
Mistake ?
Version 0.1.21 fixes that issue (in first post of this thread)
Sorry,I don't see it fisrt time ! I'll test it
Have a good day
version 1.21 is the most recent?
Yes
Thanks, going to install it now.
Just installed the Version 1.21 and it works great. It already installed three updates and no issues, very nice and light.
Nice touch with the Dai icon for the apt updater when I added it to my desktop.
Thank you
That's also the default icon for themebackup.
I almost missed the Dai scripts in the menu when I was looking around for the uninstall you mentioned. Im so use to generic my head completely missed it.
Dont worry I didnt uninstall it,
I'e had it runnng on my systems and I haven't had any problems since it was last updated, but I know it's not for everyone so I don't get offended if it's not used, hopefully when I finish version 2 it will be a "different beast".
Looking forward to the newer version and I like beasts...
The other night the Apt Updater reported no updates but Symantec showed three files for install. Thats the only time Ive seen that happen, otherwise its been working very well. Ive been noting when the updater checks for updates.
This can happen in the time between Apt being updated and the timer of Apt-Updater checking the status (1 hour by default). This time interval can be set differently to suit the user, but there could always be a certain amount of time before Apt-Updater will show available updates.
I could look into finding what signals are available for when apt has updated, but I'm not sure if I could latch onto it...
Its not a big deal, but something I noticed right after Apt Updater made a check, then I immediately went to Synaptic and found updates were available.
So you clicked "Check updates Now" from the system tray icons context menu and it reported no updates and then synaptic said there were some?
Yes, thats what happened. So far its happened only once but Ill keep checking it.
I can't reproduce it here, I can introduce an update and it has never failed to find it...
Did you happen to notice if the Apt-Updater icon in the system tray had a red cross in it?
No it didnt have a red cross. Ill continue to keep an eye on it.
Ok thanks, and thanks for letting me know.
No problem, and I love the app.
Just reporting back after using the app on a large number of installs and its working great and clients love it.
Thanks CC, I think it's simplicity is quite a good feature for users and when I do start to revamp it it should be even better.
My seniors using donated systems really enjoy it as they really never cared for the more ornate update notifiers.
