#1 2016-04-14 20:11
printscreen while displaying manu
I am having issues getting a screen grab while an application menu is showing, Is there a way to get printscreen to work while an application menu is showing?
I don't know if maybe the control keys are either disabled or diverted when a menu has focus or something like that? Any suggestions that don't involve installing another application for grabbing the screen would be great. smile
#2 2016-04-14 20:51
Re: printscreen while displaying manu
We will try to investigate the reason of this issue. At the moment, we can only recommend to install the 'ksnapshot-trinity' package, it's very lightweight and powerful and you can set a delay before screen grab, however we know, you don't prefer such solution.
#3 2016-04-14 21:30
I would prefer a solution that doesn't use another package but for now I will use 'ksnapshot-trinity' as a workaround, Thank you. smile
#4 2016-04-15 01:15
DavidB
You mean, like this (the attached image)?  I did this just by pressing PrintScreen.  Seems to work on my netbook.
Now, when I pressed the print screen key, the SeaMonkey menu closed, but not before print-screen captured the image.
Not sure if this helps or not.
#5 2016-04-15 01:27
You have highlighted something to me that might be significant, I just tested this with the browser (Firefox) and it does the same as yours and manages to grab the picture before the menu disappears, I will have to look at how my app takes focus because when it is showing a menu printscreen does nothing... Thanks for the info though, it points more to something I can put right and hopefully save the dev's having to dig too deep. Thank you. smile
#6 2016-04-15 02:51
DavidB
Hey, you're most welcome!  Glad it was useful in some way.
