Bonjour
Je me demande si sur mon eeePC 1000H avec Q4os passer de 1Go à 2Go ce sera mieux.
J'ai entendu dire *que sur certains os cela ne servait à rien
Merci a vous
Good morning
I wonder if on my eeePC 1000H with Q4os going from 1GB to 2GB will be better.
I've heard that on some sites* that with somme os it doesn't help to have more ram.
Thank you
*ccm
Asus Eee PC 1000H Atom N270 à 1.6 GHz ram 2go avec Q4os 3.16.1 centaurus
I have an EeePC 1011 that is slightly newer than yours.
Yes, installing 2Gb RAM made some difference. An SSD hard drive made a bigger difference.
The issue is that you still are left with a 32bit motherboard therefore you need to install a 32bit OS. It works but not well. It is difficult with the internet. It will probably work well as a single use machine. I have mine running a server for playing audio and that's it.
I'm looking around for a refurbished 64 bit laptop and then I'll install the smallest Q4OS and minimum audio software and that's all.
sub13,
What did you do?
If you are often near or at 100% it could be worth upgrading your RAM, but first of all check in the PC specifications if the motherboard supports 2 GB RAM.
Edit:
To know memory usage use htop for example
$ htop
EEEPC 1000H supports up to 2gb of memory, definitely worth doing.
Bonjour
Merci pour les conseils entre 2 j'ai tester avec Lubuntu et J'ai mis 2go de ram et suis revenu à q4os.
Ça a l'air d'aller mieux.
Merci
