#1 2016-02-26 14:01
Jerome
Creating a bootable usb
I have Q4OS on my main desktop and would like to install it on my netbook (which doesn't have a cd drive). I'm not sure how to create a bootable usb drive or what software is available to do this?
Any help appreciated.
#2 2016-02-26 14:36
Re: Creating a bootable usb
The easiest way is to plug your usb in, do not mount it, and run in terminal:
$ sudo cp iso-file.iso /dev/sdx
where
'sdx' is the target usb drive, for example 'sdb'
'iso-file.iso' is downloaded cd image, for example 'q4os-1.4.7-x64.iso'
Alternatively you can use 'unetbootin' software.
#3 2016-02-26 14:57
Jerome
Thanks q4osteam, the first option worked ok.
By the way, very nice OS. I've been looking for a replacement for XP and this is excellent.
#4 2016-02-26 17:11
Jerome
Having successfully installed Q4OS on my netbook I would like to restore my usb stick to its original state; how do I do that?
Thanks again and sorry for the noob questions.
UPDATE: I figured it out. I guess I should use Google first before coming here... ;-)
#5 2016-02-26 20:52
big_smile Guilty smile
#6 2016-02-26 20:53
bobby
Oh So Much do I do that sad
No Longer Using Q4OS
#7 2018-01-09 04:15
Gamsoer
where
I used to follow this guide to create bootable DVD . Obviously I failed, the DVD or CD is not a good carrier, now i wan to try making bootable USB ,
If the USB can be booted , How much memory do we need for USB ? any effective user guides ,
