#1 2022-12-23 09:58
photino
[SOLVED] how to suppress password to open session ?
I have just installed q4os/Trinity  (basic version) but forgot to select the option "no password required to open session"  how can I do that now ?
Thanks for your help
#2 2022-12-23 11:01
Re: [SOLVED] how to suppress password to open session ?
Welcome screen > Set autologin
#3 2022-12-26 17:52
photino
The display of the welcome screen has been suppressed, how can I display it again ? .
In the «  Configuration  Center » the password can be changed but no option  concerning the opening of a session.
Is there a command in a Terminal to fix that ?
#4 2022-12-26 19:59
$ welcome-screen5.exu
#5 2022-12-26 22:35
photino
Thanks to all, I could make the change in Welcome Screen
#6 2022-12-26 23:06
You can also use terminal command:
$ sudo ctrl-autologin
