#1 2022-12-04 03:20
z2168235
unable to un-mute on HP mini 210-1000
I installed Q4OS Gemini, Trinity 64bit on HP mini 210-1000, atom N450 1.66GHz.
Everything worked fine except for the mute button. I can mute but I cannot un-mute using button.
I have to do manually from KMix to un-mute.
What I see from KMix mixer is when I pressed mute button both master and speaker volume is off.
However, when I un-mute, it is only un-mute master volume, speaker volume still off.
Is there any setting to rectify this?
Thank you
Regards
Robertus
#2 2022-12-04 11:34
Re: unable to un-mute on HP mini 210-1000
Yes, we can confirm this bug. Unfortunately, we know no solution at the moment. You could try to install pulseaudio package and see what happens.
This bug apparently persists in O4OS Gemini Trinity desktop R14.0.12. We have concluded this is a Trinity bug, so it should be appropriate to report that for TDE developers. A similar issue has been reported in the past https://www.q4os.org/forum/viewtopic.php?id=3667
#3 2022-12-11 07:44
z2168235
OK, so mute button not working, got it
