Hiyall,
I'm liking it so far.
I'm trying to get Anydesk (remote desktop) to work on Q4OS-32bit+Trinity. I have downloaded both 32 & 64 bit versions. Neither work. I get a window with:"TDEInit could not launch Anydesk. Could not find Anydesk executable.".
Q4OS 5.4 Trinity 32bit Full on Asus EeePC 1011PX (2011), Atom N455, 2Gb DDR2 RAM, 256Gb SSD
Did you download the i386 version https://download.anydesk.com/linux/deb/ … 1_i386.deb or the generic linux https://download.anydesk.com/linux/gene … 386.tar.gz
Guessing that you used the i386 deb, how did you install it? The ideal method is to open the download location in Konsole and then
sudo apt install ./anydesk_6.0.0-1_i386.deb
This will pull in any required dependencies.
Alternatively use the instructions on their web site to enable the repository - the commands will need to be run with sudo as they are assuming a separate root account.
Once it is installed, if it doesn't want to run through the menu, then open Konsole and just type anydesk - that assumes that's the name of the executable. You should then get back some meaningful information.
