#1 2022-06-20 13:57
carmicheals
Cloning Windows-installed Gemini?
I have used the Windows Installer to successfully install Gemini on my Win 10 Pro laptop. Once I get my Gemini installation set up and configured the way I like it, can that installation be cloned to another Win 10 Pro machine? I have two other Windows machines that I use regularly and would like to have Q4OS Gemini set up the same way without going through two more manual setups/configurations.
If I have an image/copy of my working Q4OS Gemini setup I can also easily restore it in the event of an issue. I am no terminal/command line hero in either Windows or Linux but I take direction well (don't ask my wife...) and don't mind working through problems/issues. I have used desktop Linux - mostly Debian/Ubuntu derivatives and Puppy - for years as a hobbyist.
I have done a little searching through the forum but didn't find this specific question.
Thanks in advance for any tips/insight!
#2 2022-06-20 14:07
carmicheals
Re: Cloning Windows-installed Gemini?
Replying to myself - I can copy the Linux 64 directory from C:\ in Windows 10 to a thumb drive and from there to a target Windows 10 machine. I am guessing that installing/configuring Wubi on the target machine would be the way to make the Gemini installation in that directory bootable. Am I on the right track here?
Thanks!
#3 2022-06-20 15:27
carmicheals wrote:
,,, Am I on the right track here?
We would recommend to make a fresh installation on a new machine in order to proceed the Linux/Debian configuration properly on the target hardware. We recommend to use "custom profiles" to pass the system wide configuration on a new machine, see https://www.q4os.org/dqa016.html
If you know what you are doing, you can try to boot just configured image, so you need to copy/rewrite the file "c:\linux64\debian11\disks\root.disk" only. Keep in mind, you could end up with a broken system, as the loop image has been configured for another hardware.
#4 2022-06-20 16:37
carmicheals
It looks like the "custom profiles" function is the way to go. I will experiment with that, and thanks! That would still save a bunch of time and keystrokes over separate installs/configurations!
#5 2022-07-04 05:48
carmicheals
Ran the Windows Installer on another machine. Tried "Custom Profiles" first. The issue there is that my installation has some software installed that wasn't from the Q4OS Software Centre.
I then renamed C:\Linux64\Debian11\disks\root.disk on the target machine to root.disk.old and copied the root.disk file from my original Windows machine over.
It takes a fair amount of time to boot once selected (it gets stuck for several minutes at "Initializing system during boot), but it works. Is there anything I can do within wubiuefi to speed this up? A boot configuration file that needs editing, maybe?
My original root.disk file was created on an i7 Toshiba laptop. I migrated it over to a Lenovo AMD desktop, and ran updates from terminal after it booted to make sure all of the differing hardware was accounted for. it works great once it finally boots.
#6 2022-07-05 15:25
carmicheals
I am guessing that this is a UUID issue. Since the boot.disk file was created on another machine it likely contains the UUID from the host machine. The boot configuration post-"Initializing system during boot" on the target machine is looking for a different UUID which creates the delay. That's my theory, anyway.
#7 2022-07-05 16:30
Yes it could be.. Check for swap UUID in /etc/fstab and modify it accordingly.
