#1 2022-04-17 15:27
Orange dots and widgets in System Configuration
I just noticed orange dots beside a few options in System Configuration and in each of these options there is also some orange widgets in the right panel (see attached screen capture).
Does these orange dots indicate a configuration problem? In this case how can I know what the problem is?
Q4OS upgraded from 4.7 to 4.8 some days ago and I didn't notice this before.
I also activated the backup option in System Configuration, but I don't know if it is related.
Thanks for any help.
#2 2022-04-17 15:38
Re: Orange dots and widgets in System Configuration
These markers indicate changed settings. You can easily turn them off clicking on the "Highlight changed settings" button in system settings
#3 2022-04-17 17:50
Thanks for your answer. I've just located the button.
In French its text is "Surligner les paramètres modifiés", which doesn't describe correctly its effect: "surligner" means to give this aspect. In my opinion, a better button text would have been "Indiquer les paramètres modifiés".
By the way, Applications > Locations is marked as modified although I didn't modify them; the directories were just translated to French at the installation time ("Videos" -> "Vidéos" and so on). If I click there on the button "Réglages par défaut" (Default settings), the English wordings are used.
On the other hand, I modified the backup tool (activation and creation of a backup template) but it isn't marked as modified.
Anyway, I have to say that the introduction of the backup tool is a very, very, very excellent idea!
