#1 2021-08-03 04:57
Stop folder autocreation
I SWEAR I've asked this before, but I can't find it in a search, so asking away.  How do you keep Q4OS from auto recreating the folders in your home drive.  I know which folders I want, and which I don't, and I don't need the system to keep creating folders that I don't need.  In fact, I don't even want it creating folders that I DO want...I'm perfectly capable of typing mkdir.
#2 2021-08-03 09:09
Re: Stop folder autocreation
You likely need to edit files:
$HOME/.config/user-dirs.dirs
$HOME/.configtde/user-dirs.dirs
$HOME/.configkde/user-dirs.dirs
The contents of those files should equal.
#3 2021-08-03 14:11
I deleted all lines from $HOME/.config/user-dirs.dirs & $HOME/.configtde/user-dirs.dirs, I don't have a $HOME/.configkde/user-dirs.dirs file, but the stupid folders still keep reappearing.  What next?
#4 2021-08-04 05:50
Probably this is being caused by /etc/xdg/autostart/xdg-user-desktop which triggers xdg-user-dirs-update - which makes sure the standard user folders are in place.
Just move that out of /etc/xdg/autostart/ and hopefully all will be well.
#5 2021-08-05 02:25
Yes, this stopped those folders from coming back!!  Thank you!!!!  So much happier with my install now that I have just the folders I want.
