#1 2021-03-28 14:21
simstim
Conky formatting
Hi
I have managed to get Conky running in Q4OS, but any Conky theme I use has a drop shadow added to the Conky window, even with all the window formatting disabled in Conky. I suspect this may have something to do with the Trinity Desktop compositor. Is there a specific setting that excludes Conky windows from compositor formatting?
#2 2021-03-28 17:02
Re: Conky formatting
simstim wrote:
Hi
Show us your .conkyrc or conky.conf file.
#3 2021-03-28 18:19
simstim
Here is the conky.conf content:
# Minimalis Conky 1.3
# Author : archit3x
# Release date : 4 December 2020
# Tested on : Archlinux ARM - XFCE Desktop
# Email : archit3x@archlinux.us
# Feel free to modity this script ;)
conky.config = {
    alignment = 'top_right',
    background = false,
    border_width = 0,
    cpu_avg_samples = 2,
    default_color = 'gray',
    default_outline_color = 'white',
    default_shade_color = 'white',
    color1 = '#eaac14',
    double_buffer = true,
    draw_borders = false,
    draw_graph_borders = true,
    draw_outline = false,
    draw_shades = false,
    extra_newline = false,
    font = 'Droid:size=9',
    gap_x = 30,
    gap_y = 30,
    minimum_height = 250,
    minimum_width = 220,
    net_avg_samples = 2,
    no_buffers = true,
    out_to_console = false,
    out_to_ncurses = false,
    out_to_stderr = false,
    out_to_x = true,
    own_window = true,
    own_window_transparent = true,
    own_window_argb_visual = true,
    own_window_argb_value = 0,
    own_window_class = 'Conky',
    own_window_type = 'normal',
    own_window_hints ='undecorated,sticky,skip_taskbar,skip_pager,below',
    show_graph_range = false,
    show_graph_scale = false,
    stippled_borders = 0,
    update_interval = 1.0,
    uppercase = false,
    use_spacer = 'none',
    use_xft = true,
conky.text = [[
${color1}${font ConkySymbols:size=20}t${font} ${voffset -10}GNU/Linux» $hr ${color}
${color1}${goto 35}OS     : ${color}${execi 86400 cat `ls -atr /etc/*-release | tail -2` | grep "PRETTY_NAME" | cut -d= -f2 |  sed 's/"//g'}
${color1}${goto 35}Kernel : ${color}$kernel on $machine
${color1}${font ConkySymbols:size=16}f${font} ${voffset -10} System» $hr${color}
${color1}${goto 35}Core 1 : ${color}${freq_g 1}GHz ${alignr}${cpu cpu0}% ${cpubar cpu0 4,100}
${color1}${goto 35}Uptime : ${color}$uptime_short
${color1}${font ConkySymbols:size=16}J${font} ${voffset -10}Memory» $hr${color}
${color1}${goto 35}RAM : ${color}$mem/$memmax ${alignr}$memperc% ${membar 4,100}
${color1}${goto 35}SWAP: ${color}$swap/$swapmax $alignr}$swapperc% ${swapbar 4,100}
${color1}${font ConkySymbols:size=16}k${font} ${voffset -10} Storage» $hr${color}
${color1}${goto 35}ROOT : ${color}${fs_used /}/${fs_size /} ${alignr}${fs_used_perc /}% ${fs_bar 4,100 /}
${goto 35}
#4 2021-03-28 20:11
# Author : archit3x
conky.config = {
    background = false,
    border_width = 0,
    color1 = '#eaac14',
    gap_x = 30,
    gap_y = 30,
    no_buffers = true,
    out_to_x = true,
    own_window = true,
    uppercase = false,
    use_xft = true,
conky.text = [[
${goto 35}
Try changing
background = false,
to
background = true,
and remove
note that it needs to be removed, commenting won't work. Make a conky.conf copy first, if you like.
cp /path/to/conky/conky.conf  conky.conf.bak #sudo cp if /path/to/conky/conky.conf is /etc/conky/conky.conf
then try the changes I suggest, if they don't work, just revert the changes
cp /path/to/conky/conky.conf.bak conky.conf #use sudo if needed as explained above
#5 2021-04-01 14:41
simstim
Thanks, I will try these changes.
