#1 2021-03-26 09:19
Aristide
[CONCLUSION : BUG DEBIAN RELATED] - Probem with icons with Apper
Hello !
I have installed Apper for manage software, but I have a problem, I don't have icons¹ (Screenshot : 1)
I have try to install Qt5ct and set QT_QPA_PLATFORMTHEME=qt5ct its work (Screenshot : 2) and launch (QT_QPA_PLATFORMTHEME=qt5ct apper) : Its work.
BUT, problem is here :
I try to set QT_QPA_PLATFORMTHEME to qt5ct but this env var is set as q4ostde. I have try several methods :
→ Set variable in .bashrc and .profile (I don't have .bash_login) in my home directory. QT_QPA_PLATFORMTHEME is set as qt5ct if I launch konsole, but not from session manager.
→ Modify /etc/X11/Xsession.d/99qt5ct for force set : Don't set.
Do you know where QT_QPA_PLATFORMTHEME is set as q4ostde ?
Thank's smile
# Enable qt5ct by default unless another PLATFORMTHEME option is set
# or KDE is running.
#if [ -z "$QT_QPA_PLATFORMTHEME" ] && [ "$XDG_CURRENT_DESKTOP" != "KDE" ]
#then
export QT_QPA_PLATFORMTHEME=qt5ct
#fi
Screenshots :
1 : Screen 1
2 : Screen 2
#2 2021-03-26 09:24
Aristide
Re: [CONCLUSION : BUG DEBIAN RELATED] - Probem with icons with Apper
So, I add informations :
I have try to add a script shell (and chmod +x) for set variable into ~/.trinity/env and ~/.trinity/Autostart too : Same problem.
I use trinity Desktop
#3 2021-03-26 09:49
What desktop profile do you apply at install phase ?
You shouldn't modify the "QT_QPA_PLATFORMTHEME" variable, as it defines theme for QT5 applications to integrate in Trinity. We would recommend you just to install "oxygen-icon-theme" package to add the needed icons:
$ sudo apt install oxygen-icon-theme
The  QT_QPA_PLATFORMTHEME is defined in "/opt/trinity/env/50_q4loginscr01.sh", however we wouldn't recommend you to modify it, as noted above. You can also edit the file "$HOME/.configtde/q4tde/q4tde.conf" file to change QT5 settings in Trinity, it's the recommended way.
#4 2021-03-26 09:57
Aristide
Hello !
Thank's for your response smile
I use breeze theme icon (sorry, I forget to specify).
OK. I try to edit this file but I have same problem (try after logoff/logon).
[General]
icon_theme=breeze
;single_click_activate=false
;theme=light
;tool_button_style=ToolButtonTextUnderIcon
[Mouse]
cursor_theme=breeze_cursors
[Qt]
;doubleClickInterval=400
;font="Droid Sans,9,-1,5,50,0,0,0,0,0"
;style=Fusion
;wheelScrollLines=3
user@q4os-desktop:/usr/share/icons$ ls
Adwaita         Breeze_Snow      desktop-base  hicolor      Tango
breeze          cab_extract.png  DMZ-Black     locolor      vendor
breeze_cursors  cab_view.png     DMZ-White     oxygen       Waterleaf
breeze-dark     default          gnome         q4os-nuvola
For profile, I have selected « TDE » desktop with full desktop set.
#5 2021-03-26 10:00
Well, the applications seems to not respect the icon settings. So, please try to uncomment the "style" line in the "q4tde.conf" file.
#6 2021-03-26 10:12
Aristide
Hm. Ok. I have try to edit q4tde.conf (both style=Fusion (default) and QtCurve, and Breeze : Same problem).
App theme is changed (in direct live), but not icon (I have again try to logoff/logon).
But its strange, because only « Apper » is impacted by this problem.
Kdevelop is loaded correcly with icons.
#7 2021-03-26 10:24
You could also try to run affected applications from terminal and check the terminal output for errors.
#8 2021-03-26 10:33
Aristide
Hm. Maybe this « pixmap » error :
user@q4os-desktop:~$ apper
QCommandLineParser: option not defined: "install-provide-file"
kf5.kwidgetsaddons: Invalid pixmap specified.
apper:
apper:
This error not appear with qt5ct :
user@q4os-desktop:~$ QT_QPA_PLATFORMTHEME=qt5ct apper
qt5ct: using qt5ct plugin
apper:
apper:
#9 2021-03-26 10:41
We will investigate the issue and post back on updates.
#10 2021-03-26 10:44
It would be also helpful, if you summarize the issue and create a new report at our bug tracker https://sourceforge.net/p/q4os/tickets/ . Thanks for reproting.
#11 2021-03-26 16:41
We conclude it's a Debian upstream bug. The same issue shows at a clean pure LXQT Debian installation https://cdimage.debian.org/debian-cd/cu … 4-lxqt.iso , so it would be appropriate to report that as a Debian bug.
#12 2021-03-27 12:32
Aristide
Hello.
#13 2021-03-27 15:43
Getting qt5 apps to behave can be a pain. Getting them to behave in TDE is even more of a pain to impossible.
However, the assumption that it is a bug may be incorrect.
Installed Debian LXQT as above.
Installed qt5ct (the style plugins are already installed)
Run
env QT_QPA_PLATFORMTHEME=qt5ct qt5ct
It takes a few moments to load.
Configure using Fusion, Sans/Mono, Oxygen Icons and save.
Install apper
Run apper - it glitches as previously described
https://imgur.com/vu0TG3o
So, you need to set the environment on launching the program
env QT_QPA_PLATFORMTHEME=qt5ct apper
https://imgur.com/QUsfYaC
All good. You can fit this into a custom launcher.
As regards doing this in TDE - well I find it easier to use a VM running LXDE (LXQT or XFCE will do) to create the ~/.config/qt5ct folder and just drop it where I need it.
