#1 2021-01-23 12:46
itsoulos
Gtk applications on Macbook Pro with Retina
I have installed with success Q4OS Gemini 4.2 on a Macbook Pro mid 2014 with Retina Screen.
Everything works ok but some apps such as Firefox and Netbeans have very small fonts on the title bar
and on the menus. How can i scale them to some desired font size?
#2 2021-01-23 13:35
itsoulos
Re: Gtk applications on Macbook Pro with Retina
Update: after using the default jdk the advice from https://stackoverflow.com/questions/440 … -4k-screen the fonts in Netbeans have been corrected. Still looking for some help in Firefox
#3 2021-01-25 14:23
Have you tried changing to high DPI settings?
E.g., check https://winaero.com/enable-hidpi-scaling-firefox/.
#4 2021-01-27 16:45
@itsoulos
You need to configure screen scaling to a proper value.
#5 2021-02-26 17:39
itsoulos
The problem is not solved. The only action that solves the problem is to open from kde settings the
gtk settings and select the Breeze style, but this action should be performed on every login!!
Strange behavior
