#1 2020-11-10 12:43
Peter Rossa
How can I reduce the side of my screen please?
My display is too big for my monitor so top, bottom and both sides are missing, how can I reduce this please so I can view my whole display?
#2 2020-11-11 07:08
Re: How can I reduce the side of my screen please?
It depends on which version you are using.
In Trinity TDE version you can use the TDERandRTray - Screen Size and Rotate utility in the system menu to get to the right setting. Once you know what that is you can then use Control Centre>Peripherals>Display to set that value and use the checkbox to apply on startup.
If you are using Plasma I cannot be sure about the TDERandRTray bit, but the setting in Control centre should still be there.
#3 2020-11-11 11:06
Peter Rossa
Hi and thanks, I am using the Trinity TDE version, can you tell me where I might find  TDERandRTray please?
#4 2020-11-12 06:20
You're welcome.
Start>Programs>Accessories>System
OR
Just type TDER in the search box at the bottom of the start menu (provided you are using the default start menu)
