#1 2020-11-06 21:45
BOB68
Q4os Centaurus 3.0 installation problem
Hello. I have this problem: The Q4os Centaurus 3.0 installer displays the following: Please select the target directory. Next The installation no longer works. What should I do next?
My computer has a new Windows 10 home installed.
Samsung R522
Intel Core Duo T9400 processor, 2,53 GHz
RAM 4GB
HDD 1TB Hybrid Divided into 2 partitions in half.
Of course Windows 10 is working fine.
#2 2020-11-06 22:16
Re: Q4os Centaurus 3.0 installation problem
We are not able to reproduce the issue, please describe it in more detail. What installer do you use ? What phase setup fails in ? Are there some error messages ? A screenshot would be helpful too.
#3 2020-11-06 22:44
BOB68
The installer is downloaded today from https://www.q4os.org/downloads1.html
But please wait. I think I know what the problem is. I made too much space for installation (250GB). Try a smaller one. Of course I will send you information about the results...
#4 2020-11-07 10:38
Thanks for reporting, it helps us in bugs hunting. We would appreciate a detailed procedure to reproduce the bug, as we are not able to reproduce it now. An error screenshot would be helpful too.
