#1 2020-09-28 17:12
antares
Appimage installation problem
Hi !
Downloaded LosslessCut-linux 3 23.AppImage  unziped with ark made executable but no any response to clicking
This is not the first time appimage application refuses to get active
What is wrong with appimage in general?
Please help to install losslesscut
#2 2020-09-28 17:21
Re: Appimage installation problem
antares wrote:
Hi !
Where did you download it? From here https://github.com/mifi/lossless-cut/releases ? I ask because you wrote "LosslessCut-linux 3 23.AppImage" and the actual name's "LosslessCut-linux.appimage". Nothing's wrong with appimages in general. I use quite a few myself and they all work fine, however, I have noticed some electron based appimages do tend to fail due to permissions issues. Try running the app from terminal:
1. cd into appimage directory
cd /path/to/appimage
2. run the appimage from terminal
./LosslessCut-linux 3 23.AppImage
3. check/look for any messages you may get in the terminal as these will help troubleshooting the issue.
BTW, when downloading appimages, is a good practice to make sure it does have support; that it has a github page, for example.
Hope this helps! smile
#3 2020-09-28 21:44
antares
Yes downloaded from there
Tried to follow the path you ve shown
No result
#4 2020-09-29 06:52
The appimage is called LosslessCut-linux.AppImage.
First of all make it executable
robin@flopsy:~/Downloads/applications$ chmod +x LosslessCut-linux.AppImage
Then try to run it - there's a bit of a problem as below.
robin@flopsy:~/Downloads/applications$ ./LosslessCut-linux.AppImage
[2274:0929/063141.585113:FATAL:setuid_sandbox_host.cc(157)] The SUID sandbox helper binary was found, but is not configured correctly. Rather than run without sandboxing I'm aborting now. You need to make sure that /tmp/.mount_Lossle4wyNQh/chrome-sandbox is owned by root and has mode 4755.
Trace/breakpoint trap
So, after you have made it executable - as above - run it like this and it will work
./LosslessCut-linux.AppImage --no-sandbox
