#1 2020-04-02 09:50
Mr Chaben
I can't start my PC because of a Q4OS problem
Good morning.
My PC has Q4OS 32 bits Trinity.
When I boot my PC, I have this error message that appears:
- Unable to start tdestartupconfig. Check your installation.
- Call to lnusertemp failed (temporary directories full?). Check your installation.
When installing Q4OS, I chose the fully automatic installation.
My config is:
- RAM: 1 Go DDR (2*Kingston KVR400X64C3A 512Mo)
- Storage: 40 Go PATA
- Graphics: MSI RX9600XT-TD128
- Processor: I don't remerber. Just, I know it's a AMD processor socket T462
I would like to point out that the PC I use has the i686 architecture.
PS: Have you got a solution to repair this problem?
#2 2020-04-03 07:27
Re: I can't start my PC because of a Q4OS problem
It is likely your $HOME directory is inaccessible by normal user.
Try to write anything to your $HOME:
$ touch $HOME/.test.tmp
and see the terminal output.
Furthermore check the permissions of $HOME.
#3 2020-04-04 16:34
Mr Chaben
Good morning.
Finally, I've installed Q4OS again, and I don't have this problem anymore.
Thank you anyway for your help, wishing you a good day.
#4 2020-07-08 06:29
detoo
Can user and group ownership be restored if both are accidentally changed to /root and you are unable to log in to your desktop? And if so, how would this be done? Thank you.
#5 2020-07-08 09:09
Run in terminal:
$ sudo chown -R "$FUSERNAME:$FUSERNAME" "/home/$FUSERNAME/"
#6 2020-07-09 04:48
detoo
Run in terminal:
Do you literally use $FUSERNAME, or would it be $FJOHN if John is one of the users whose desktop cannot be accessed?
#7 2020-07-09 07:55
Please substitute the $FUSERNAME with the real login user name, for ex. "john"
#8 2020-07-10 20:16
detoo
Run in terminal:
I cannot access a terminal at the login screen, and if I press the ESC key at bootup, and then select advanced options and recovery mode, I still can't get in without a root password, which is disabled by default.
#9 2020-07-15 10:55
You can try to restore your root password using Rescatux.
Keep in mind, that graphical interface is not shown if you have newest AMD videocards from 2020 (Bug).
#10 2020-07-21 03:55
detoo
OK, thanks for the info! smile
