#1 2020-04-03 00:17
BrJPedro
Where's the "Software Downloads" section, on the Downloads page?
It's still mentioned on the section 2 here https://www.q4os.org/dqa006.html
I was searching for it now, lol
João Pedro -o- @12h01
#2 2020-04-03 07:18
Re: Where's the "Software Downloads" section, on the Downloads page?
It's not active anymore. We will fix the documentation, thanks for the notification.
#3 2020-04-04 09:31
Fixed. Thanks for reporting, you are welcome to report any other bugs you find.
#4 2020-04-04 13:32
BrJPedro
Thank you.
But...
...if software section is not active anymore, where can I find "Q4OS Development Pack"?
And btw, it's also mentioned on section 2 here https://www.q4os.org/dqa008.html
Edit: And here too https://www.q4os.org/dqa009.html lol
Edit: http://www.q4os.org/downloads_app2/setu … a2_all.esh The direct link still works smile hahahah
But it isn't supported by Q4OS anymore? Why it was removed?
#5 2020-04-04 14:59
The documents will be fixed as well. You can find the direct link to development pack at the developers section https://www.q4os.org/developer.html , devpack has never been dropped, it's still supported.
Edit: Fixed, thanks for reporting.
