#1 2019-05-15 18:54
hitsware
Sound on RPi version ....
I like the desktop !
But,
1) volume control has some effect but won't turn down
2) sound from HDMI but not headphone jack
My system works fine with Raspbian.
I tried adjusting the KMix settings, but to no avail.
Thanks for any help.
#2 2019-05-15 19:56
Re: Sound on RPi version ....
You could use PulseAudio volume control too, run in terminal:
$ pavucontrol
or
$ pavucontrol-qt
Q4OS is based on Raspbian, so settings should be the same.
#3 2019-05-15 22:55
hitsware
from the terminal alsamixer has full control
from the tray the Kmix sliders (full swing) only slightly move the alsa control
Raspbian does not have Kmix
#edit
VLC volume slider works
Sonic Pi volume works
Possibly Kmixer is for X86 systems ? ( wild guess (newbie here) )
#4 2019-05-16 07:12
No it's compiled for Raspbian, so ARM architecture. Please follow the documentation https://www.q4os.org/dqa011.html#install.3 . Does "Pavucontrol" work ?
#5 2019-05-16 16:29
hitsware
O.K.......Thank You.................Works now..........Would be nice to be that way 'out of the box' smile
