#1 2019-04-03 19:44
Marcus
Actions in Menu
Hi all.
I am trying out q4os 3.5.3-n1 and noticed that when I enter e.g. editor in the search field within the menu there now appears an action on top like 'run /usr/bin/editor'.
Is there a way to disable this behavior that the application is shown on top again so I can just search for the application name and press enter to launch it?
Greetings
Marcus
#2 2019-04-17 11:06
Re: Actions in Menu
Unfortunately, there is no way to disable this behavior at the moment. We will check for a possible fix, thanks for reporting.
